Dryers Logo
A
Anonymous Posted on Mar 19, 2012
Replace belt on Whirlpool LFE5800 dryer - Dryers
1 Related Answer
hunter19_46m
Curtis Sewell
  • 7482 Answers
  • Posted on Oct 21, 2009
SOURCE: WHIRLPOOL DRYER
Your problem sounds like you have drum rollers in need of lubrication.
If you have a front loading machine.
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
While you have the drum out, Now is the time that you should lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil.
Check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
How to change the belt on a whirlpool AWZ7814 AL
These dryers have common roots with lots of other brands. You should be able to see what you need via either video:
How to Change Dryer Belt on Whirlpool Dryer or in Instructables
How To Replace Dryer Belt on Whirlpool Models
Belt replacement
This article I wrote will assist you to replace the belt
How Replace The Belt on Your Whirlpool Dryer
Your dryer is made by whirlpool and this is how to replace the belt
2helpful
Replace belt on whirlpool gas dryer ggw9250pw3
Below is a video with step by step instructions for replacing the drive belt on a front loading whirlpool gas dryer. Best of luck!
Greg
1helpful
How do you gain access to rge belt drive to replace broken belt on the LEN2000LW dryer.
you will need to open the cabinet:
http://www.partselect.com/dryer+new-whirlpool-open-cabinet+repair.htm
then replace the belt:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
hope the helped Tim
1helpful
Drum will not turn on dryer makes a high pitch shrill when you push the button
u are going to need to replace the dryer drum drive belt and inspect the rollers the drum ride in, here is how to replace the belt.
please follow the safe link to the how to site on your dryer.
http://www.instructables.com/id/How-To-Replace-a-Dryer-Belt-on-Whirlpool-Models/
4helpful
2answers
How to install belt on whirlpool dryer lew 0050pq
Hello, Here is a guide to replacing whirlpool dryer belt's with pictures: http://www.wonderhowto.com/how-to/article/replace-a-dryer-belt-on-whirlpool-models-0104520/ If you have any questions or concerns please feel free to comment again giving me time to respond. Good Luck!! Mike
Top Dryers Experts
john h
