First got a error code ca00 and it said to reboot. After reboot, got an error code ce40.
I want to locate the position of the image sensor for a toshiba E-Studio2500c.
Posted on Jul 19, 2012
SOURCE: Toshiba eStudio 2500c - CA00
the 2692 doesn't work,
it's possible that this code have been changed?
how can i know the list code pour 2500C series?
Posted on Jul 16, 2010
SOURCE: toshiba estudio 351c error code
Hi [CE40] Image quality control test pattern abnormality (1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color. (2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" to check if the low-density pattern abnormality occurs for each color. The values under 320 for Y, M and C, and under 220 for K are defined as low-density pattern abnormality. (3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" to check if the high-density pattern abnormality occurs for each color and identify the color which pattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality. (4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image quality closed-loop control / Laser power (08-557)" to "0" (Invalid). (5) Perform "Enforced performing of image quality open-loop control (05-394)". (6) Output the image quality control test pattern (04-270) more than one time and check the patch of the color identified in step (3) to see if the image is abnormal. (7) Replace the image quality sensor. (8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image quality closed-loop control / Laser power (08-557)" to "1" (Valid). (9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it is completed normally. (Error [CE40] does not appear.) (10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576). Good Luck Regards
I hope that this will help you
Posted on Apr 12, 2011
Sep 29, 2018 | Toshiba Office Equipment & Supplies
Jun 06, 2018 | Toshiba Office Equipment & Supplies
Oct 31, 2017 | The Office Equipment & Supplies
Jul 14, 2017 | Toshiba Office Equipment & Supplies
Aug 05, 2016 | Toshiba e-Studio 2050C Multifunction Color...
May 10, 2016 | Office Equipment & Supplies
Sep 02, 2015 | Office Equipment & Supplies
Mar 04, 2015 | Toshiba E-Studio 2830c Color Copier...
Jan 04, 2011 | Toshiba E-studio 281c Copier
Jan 15, 2010 | Toshiba Office Equipment & Supplies
Mar 05, 2021 | Epson Office Equipment & Supplies
5,601 people viewed this question
