Question about Hitachi Deskstar 7K160 HDS721616PLA380 160 GB SATA Hard Drive
I have Hitachi Deskstar 7K160 HDS721616PLA380 160 GB SATA Hard Drive bios is detected but we cant format
When i format my hard disk he cant format and cant create partition how i can do that . please sugessest me
Posted by patelbalram on
Michael Green
  • 3,799 Answers
If the operating system can't format the hard drive then the chances are that the drive is either failing or Failed.
Posted on Mar 20, 2012
5 Related Answers
rjivaro
  • 158 Answers
SOURCE: Sata Hard Drive not detected on Bios
I would tend to agree that if the ports are set to autodetect it would suggest that they are looking for drives, but go through every item in your bios just to make sure that there isn't some obscure spot where the port is turned off.
If your bios is not detecting a drive your o/s is not going to find it either, and Linux will likely have the driver it needs when you go to load it. What's more, if it doesn't, you're rather hosed until it does.
If everything looks right after checking and rechecking and sleeping on it and checking again, but your bios still won't find the drive, take the drive back and get it replaced.
Posted on Apr 30, 2009
Anonymous
  • 674 Answers
SOURCE: Hitachi Desk star 500GB SATA drive
HOW MANY PARTITION DID YOU MAKE? HOW MANY GB EACH OF ONE.?
MAYBE YOU DID NOT FORMAT THE OTHERS.JUST REVIEW YOUR PARTITION GOT TO PARTIONING ARE THEN REVIEW IT....... YOU FIND THERE THE PROBLEM,, THAT IS HAPPER TO ME BEFORE...BEST OF MY EXPERIENCE....
Posted on Jun 08, 2009
Anonymous
  • 94 Answers
SOURCE: sata HDD very slow
Dear friend you need a sata board to get maximum speed of sata driver connect it directly to motherboard sata jack converter does not give full sata speed
Posted on Jul 22, 2009
Anonymous
  • 183 Answers
SOURCE: A new hard disk drive, Hitachi part
Hello there DLBurkhart.
Here's your geek-steer ...
"...is emitting strange whining sounds every now and then ... Is this strange noise a sign of an impending problem?" == EVERY strange HDD noise is ALWAYS a sign of impending failure.
Peform a "Check Disk" on it ...
chkdsk DRIVE_LETTER /X /R
  • There should be NO surface errors if it's new(er).
  • Regardless, if it's new, then immediately insist upon a replacement.
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
Today's the best day of my life ... and NOW you're part of it!
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Posted on Oct 13, 2009
Testimonial: "Straightforward advice, actually reads the problem pays attention to what you say rather than skimming and throwing out half-hearted recommendations."
SOURCE: Trying to install Hitachi Deskstar
Can you look in the bios and see if your motherboard is configured to use your SATA drives in AHCI mode or to emulate IDE mode?
Posted on Jul 28, 2011
My hard disk was being used in an HP machine now it cannot be detected by the machine or any other machine the harddisk is hitachi deskstar model HDP725025GLA380 help me
dear sir,
i think your hard disk is broken.. try to put your hard disk in a refrigerator for one night and then try to connect again to your machine, if you still get the same problem i think you need a new hard disk
May 17, 2011 | IBM HITACHI Deskstar P7K500...
HOW CAN I SET IT TO SATA 1.5 ? mY MOTHERBOARD COES NOT SUPPORT HDD WITH SATA 3.0 !
It should be backwards compatable
but it might be that you have to switch a jumper. instructions for this should have come with the hardrive itself but if not check this out
http://www.pcguide.com/byop/byop_SettingHardDriveJumpers.htm
please mark as answered if this helped solve your problem so others in similar situations can find the answer easier
Mar 12, 2011 | Hitachi Deskstar 7K160 HDS721616PLA380 160...
Hitachi Deskstar - Model HDP725050GLA360 Sata 3.0 500 GB S/N RJ3KSXHE Clicking sound after being dropped. Is there any hope of recovering the data on this drive at a reasonable price?
if the hard disk has crashed and the sound when it runs later he failed to be detected by the system, it is difficult to restore the data in it because it was not detected by the computer. The cheapest way is that you replace with only secondhand.
Feb 20, 2011 | Hitachi Deskstar P7K500 (HDP725050GLA360)...
At boot up my Hitachi Hard drive clicks once. Not shown in BIOS
Sounds like a system area problem. If you want to send it to us at TechRx, Inc. we can take a look for you. Free estimates http://techrxgb.com
May 14, 2010 | Hitachi 80GB IDE Hitechi DeskStar 7K160...
I am assuming that this is the hard drive in the computer. Try a safe boot up to see if you can get to the hard drive. use the F8 key at startup for safe mode.
Mar 24, 2010 | Hitachi 80GB IDE Hitechi DeskStar 7K160...
When I attach my hard disk I cannot power on my PC
check the jumper settings of the hard disk and power , bus connector
Sep 04, 2009 | Hitachi 80GB IDE Hitechi DeskStar 7K160...
you can check the jumper, is it on the right place?
besides, some motherboard is indeed do not support hard drive with large size on it...
Jun 08, 2009 | Hitachi Deskstar 7K500 500 GB Hard Drive
Computer
Because different computers have different internal parts. The operating system may not know about things inside of the other computer.
Dec 14, 2008 | Hitachi 80GB IDE Hitechi DeskStar 7K160...
Hitachi Deskstar 7K160 HDS721616PLA380 160 GB SATA Hard Drive Logo
341 people viewed this question
Top Hitachi Computers & Internet Experts
Marvin
Marvin
Davit Mamyan
Davit Mamyan
Michael Thomas
Michael Thomas
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
