My Philips LCD TV (26PF7321) is stuck in DTV mode, cannot access most menus, please help?
Hello, As stated above, my TV is stuck in DTV mode and I cannot select any other source. I cannot access any OS Menus except Volume Control, cannot change channels or anything else, just able to change volume and turn on/off - whether by remote or using the controls on the device. I do not own the original Remote control as I am using a universal remote. I tried resetting by unplugging for hours, but no change. I'd be much obliged to get any help with this problem. Sincerely, Dirk
Posted by alfrex on
laxmikhatiwa
My TV is stuck in DTV mode, can't get it back to TV mode. Any help out there?
Posted on Aug 05, 2012
SD Tech
    Top Expert:
  • 14,553 Answers
I would contact Phillips customer service by phone and see if this a issue common to this set and if there is a way to either do a hard reset or a software upgrade to resolve this problem.
Posted on Mar 20, 2012
5 Related Answers
Anonymous
SOURCE: Controls not working on Philips 28" TV
We had this problem with a 28PW6515. The control would work for 30 seconds after switching on, then nothing. It was diagnosed as the "glue chip" which handles all the control functions. About £200 to fix it as it's a surface mount chip.
Posted on Jun 22, 2007
Vista Electronics
  • 1694 Answers
SOURCE: remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Posted on Oct 02, 2007
Anonymous
  • 1139 Answers
SOURCE: Philips model# 27PT31, only turns on manually, no remote
Hello laurenbro, Actually it does make sense if the command processor in the TV set is bad. a way to test this would be to see if the TV will manually turn off and on. If it can, than the problem may be in the command processor IC, also called the input data IC. You will have to take this set to a TV repair shop, and have the look at that section.
Posted on Sep 12, 2007
Anonymous
  • 3 Answers
SOURCE: Wharfedale LCD3210AF Television- Digital problems!
I would imagine that the Digital PCB is faulty.
Posted on Feb 12, 2008
Anonymous
  • 252 Answers
SOURCE: Prima Tv problems
some of the tact switch of your tv are defective,or stock ,if you know how to solder, change all switches but be carefull of short circuit
Posted on Oct 14, 2008
What pixel is this tv 780 or 1020
http://www.amazon.co.uk/Philips-32-5331-HD-Ready-LCD/dp/B000IUZ944
  • Resolution: 1366 x 768 pixels
  • Display Format: 720p
  • Supported DTV Resolutions: 480p, 720p, 1080i, 576p
If this helps or solves the issue, please rate it and give a testimonial for my response.
Thank You,
Brandon
Philips 42pfl7762D-lcd blue screen, remote control
Hi! I have the probably same problem (since today) - all I know is that it is because the TV is set to digital instead of analogue, and it won't allow me to put it back into analogue mode - when I try that, i get the cross you mentioned. The strange thing is, that there are no menus visible at all. But the volume and screen output format buttons are workijng and show on the TV. Otherwise the screen is blue. Any solutions?
Hello my name is Bryan...I have a Mintek Tv Mod DTV-265D but, i can't change to mode stereo the speakers..Can you help me?
Unplug the power and replug the power the setting should go back to factory setting.U use the remote to change the tv or manually?Change batteries in the remote.
Can't Program Channels In Philips 32HF7544D/27 LCD TV
Firmware update is necessary. It is corrupted.
8helpful
3answers
BLINKING PROBLEM WITH PHILIPS FTR9965
Solved
Replace MP40 and its working perfect
1helpful
Stuck in DTV mode
Did you hit the source button till you get it back to the mode you want?
11helpful
5answers
Samsung LCD TV LN40A650 - Service Mode
1. Turn off the TV
2. Press "info" then "Menu" then "mute" and then "Power" on your remote (As fast as possible).
The TV will now start up in Service Mode
Breinholm / Denmark
Grundig gu15wdpcx. unable to access any of the dtv menu's not even to scan for channels etc, please help
With this model you can access everything apart from the DTV menus inc DTV tuning without the remote, for DTV menus and tuning you must use the remote.
Can't Change Inputs on TV
make sure that your remote is on the tv cotrle mode rather than the dvd control mode
15helpful
2answers
Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Open Questions:
Televison & Video Logo
Top Televison & Video Experts
Ekse
