Question about Makita 2704 Contractors 15 Amp 10 Inch Benchtop Table Saw
Makita table saw 2704 fence
I need to adjust the fence across the table as its "loose"
5 Related Answers
Anonymous
  • 23 Answers
SOURCE: need owners manual for makita 2703 table saw..
http://www.makita.com/en-us/Assets/images/Products/2703/owners_manuals/
Posted on Nov 28, 2008
rowdy45176
David Ford
  • 2176 Answers
SOURCE: Table Saw blade
Did you remove the center plate? It has to come out before you can remove the blade. Also make sure that the saw is unplugged before you go any further. If you still have questions contact me and I will do what I can. Also if you would like you can download a schematic of this tool at Makitatools.com just type in your model and look at the schematic. Good luck
Posted on Jan 03, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: makita table saw switch wiring
K, from what I can remember there is nothing special about the switch, however the brake works off the armature and brushes and dirty or worn brushes will affect it. I just looked at a breakdown and there is no wiring schematic on it and I did not see any electronic module for the break. You can take the brushes out (unplug tool first) and blow the area out with compressed air. Look at the brush spring for discoloration and condition and length of brush. Makita does have a good website and also a toll free number for tech support. Their site is Makitatools.com and click on the table products and then type in your saw number. Let me know if you still have a problem and I will contact a local Makita center to get more info. Good luck
Posted on Jan 08, 2009
Anonymous
i need the owner/operator manual for a makita table saw model 12711 please tell me what steps to take to get one
Posted on Oct 20, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: when I turn the table
you don't adjust the table, you need to remove the table from the base and clean the surface, when you take it apart you will see what I am talking about. To do this first unplug the tool and remove the fence and kerf boards, under the kerf boards you will find a 13MM hex bolt just like on the fence, remove the bolt and lift the table off the base, clean the wear plates and lube them with a light coat of grease, on the outside rails you will see what is causing your problem, clean with a surface conditioner or fine sandpaper, lube this area also.. Make sure you do all the sides for a smooth turn, reassemble the table to the base in reverse order and install the bolt, I usually tighten all the way snug and then loosen till you can turn the table freely making sure not to loosen too much or the table will rock. Reassemble the fence squaring it to the blade and replace the kerf boards. It sounds complicated but really it is not. This is the only way you can get that metal to metal rough turning repaired. Let me know if you need more assistance
Posted on Feb 27, 2011
HAVE OLD MAKITA 2708 TABLE SAW HOW DO I SQUARE THE BLADE
Hi rjames16,
Are you wanting to square the blade to the rip fence, to the miter fence or does the blade show runout?
To square the rip fence to the blade, lay a combination square or engineer's square along the blade with the short leg against the closest end of the fence and even with the near end of the blade. Slide the square along the blade so that the short leg is even with the far end of the blade. Loosen the lock knob and move the far end of the fence until it touches the leg of the square. Tighten the lock knob. Recheck and adjust the fence until it is perfectly square to the blade.
Adjust the miter fence to the blade in a similar fashion except that the short leg of the square will lay against the miter fence. Adjust until the long leg is aligned with the blade. The instructions for these adjustments are in the owner's manual.
You can download a copy at this website: http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=604
Copy and paste this entire address into your browser and a page will open with 2 Adobe documents. One is for the owner's manual, the other for the parts breakdown.
If you have blade runout, remove it from the saw and lay it flat. Check for warping and if warped, replace it.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 30, 2011 • Saws
My makita 2704 table saw stopped working while cutting a 4"x2" piece of timber the motor was a little hot so left it too cool an now when i try to start it up it fires up for a second or two then...
there are no capacitators that I see. What I would do is unplug the tool and remove the brushes and check there condition for burning/wear and if you can look into the brush tube and carefully turn the motor by hand and look at the commutator for discoloration. Let me know if you need more help. You can download a breakdown at "makitausa.com"
2helpful
When I turn the table I am getting metal on metal grinding and is tough to turn .... how do i adjust table? dual compound makita ls1016l miter saw
How do I adjust the rip fence on a 2703 table saw
Goto this link:
http://powertool.manualsonline.com/manuals/mfg/makita/2703.html
The instructions for adjusting the rip fence are on page 11
2answers
My makita sliding mitre saw is off a few degrees How do I adjust...non laser...10''
move the blade until it is square to the fence then loosen the screws on the table with the degree increments and set to zero.
Dw703 beval adjustment
User manual for adjusting your saw here.
When you set it up, make sure you check for square to the table, square to the fence, and check square for toe-in or at a 45 deg. angle across the blade from the corner where fence meets table, like you would check a radial arm saw. (hold a framing square with one leg against line of fence/table and other leg against blade and inclined 45 to both table and fence. Make sure all three are dead square.
I never found any way to compensate for the play in the blade itself. It seems like the manufacturing tolerances are a little too loose.
You may need a heavier plated blade. You may simply need a different saw. Those Dewalts are great workhorses, and I love the design, but it's my experience that when you're trying to miter hardwoods of any substantial size there's a little bit of drift in the cut as the blade comes through the wood.
You can try cutting at a slower rate.
I've found that makitas are a little more solid through the cut, though I don't like the general ergonomics as much...
Kind of a pain, isn't it?
Well, good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 04, 2009 • Saws
Makita 2704 I overloaded my motor
if the motor RPM drops dramatically when the noise starts, it is probably a dry motor bushing, if this just started, lubricating the motor may just fix it.
Makita 2704 Contractors 15 Amp 10 Inch Benchtop Table Saw Logo
Top Makita Saws Experts
ray gallant
Parson's Repair...
Parson's Repair...
Are you a Makita Saw Expert? Answer questions, earn points and help others
