Computers & Internet Logo
Question about Dell Computers & Internet
Laptop Battery Won T Charge on a laptop dell inspiron 1525
General Systems Consulting
    Top Expert:
  • 5,051 Answers
Battery could be dead and won't hold another charge. Batteries only last for so long until you have to replace them. If you laptop is ok with the AC Adapter & Power Cord meaning it boots and allows you to work in windows, then the battery is definitely dead.
Posted on Mar 19, 2012
5 Related Answers
Anonymous
SOURCE: Xp Drivers for Dell Inspiron Laptop 1525
I suggest to send to [email protected]
Posted on Aug 19, 2008
Anonymous
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&SystemID=INS_PNT_PM_1525&os=WLH&osl=en
Nominally you might get a more accurate answer by going to support.dell.com and entering the 'service tag' number (on the bottom of your machine next to the 'express service code'.
This machine also includes a field in the BIOS setup program; hit the F2 key when you see the Dell logo to start the BIOS setup program.
Posted on Dec 25, 2008
Anonymous
  • 19 Answers
SOURCE: Replacement battery for Dell Inspiron 1501 won't charge
Yes, they do have somethnig built in to detect if you are using a non-Dell battery, ergo you would not receive messages like "Battery cannot be identified" at boot up, and a warning that the system won't charge the battery. It is simply a ploy to ensure users buy Dell batteries at their inflated price. It's also known as anti-competitive behaviour in the business world.
Just so you know, they incorporate the same system with the power adaptor. If you use a non-Dell one, it will state that it cannot determine the power adaptor type and then let you know that the laptop will run slowly and will not carge your battery. Another way to make sure you behave and buy only Dell spares. Incidentally, with the adaptor it knows if it's a Dell one because Dell use the centre pin of the adaptor jack connector to send a 2.5V ID signal to the laptop. The positive and negative of the 19V supply is on the inside and outside of the metal barrel of the jack plug. Internal pin is solely for ID signal.
I'm afraid the only recourse is to purchase a Dell adaptor if you wish for the battery to charge. I'd recommend a second-hand one from eBay. Try to buy the highest wattage one you can.
ginko
Ginko
  • 19396 Answers
SOURCE: Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Posted on Apr 22, 2009
Anonymous
SOURCE: Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
Dell inspiron 6000 laptop battery URL(UK shop): http://laptop-battery.org.uk/laptopbattery/1001074.htm
Dell inspiron 6000 battery URL(US store): http://www.cheap-laptop-batteries.com/laptop-battery/dell-inspiron-6000.htm
Dell inspiron 6000 battery URL(AU Buy): http://laptop-batteries.com.au/computer-battery/dell-inspiron-6000.htm
Posted on Jul 31, 2009
Dell inspiron 1525 laptop battery wont charge
Hi. Download the latest BIOS from www.support.dell.com and follow the instructions carefully. If the system still doesn't charge the battery, it's either you have a dead battery or the motherboard needs replacement.
^_^
Battery not charging on a Dell Inspiron 1525 laptop?
batteries will get to the point that they will not charge at all, depending on their age and usage
Dell Inspiron 1525 battery problems.
try removing the battery and turn on your laptop, then while laptop is on, slide in the battery.
3helpful
3answers
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Dell inspiron 1525 battery doesnot charge
1. remove all external peripherals 2. try to use ac adapter alone check if laptop will power on. 3. put back batt in with ac adapter. 4. check bios (power on laptop keep tap on F2) 5. check for the bios version, battery info and battery health. 6. check if batt is 0% or 10% charge 7. check battery health and info if the ac adapter is determine or not. also check if batt is performing normally. 8. if batt has 10% charge then download the latest bios for your system. download it from support.dell.com
3answers
I have a dell inspiron 1525 and it wont charge
If possible could you check output voltage of the charger with a multimeter? If you can get output voltage, then might be something wrong with laptop battery charging circuit. Contact Laptop Repairing Engineer.
Regards;
Hassan
Ac adapter will not charge my computer
If the laptop will run from the adaptor, then the adaptor is probably fine. That being the case, if the charge light flashes when the adaptor is plugged in, the battery is faulty. No charge light on an otherwise working system is probably the battery charging circuit in the laptop.
1helpful
Clive
Clive
Steve Sweetleaf
Steve Sweetleaf
