Question about Scubapro Scuba Diving & Snorkeling
Schematics for a scubapro mk17 regulator - Scubapro Scuba Diving & Snorkeling
Posted by pulltooth on
Dan Jacobs
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 808 Answers
These are controlled by scubapro due to they need specail testing equipment to repair regulators E..G now IP pressure is 135 psi and there is no adjusting screw shims and springs then the cracking effort test to see if you have pressure flutter or creep. these can not be seen with out testing equipment.
Posted on May 16, 2014
Strange noise from mk17
Scuba pro has repair facilities everywhere they can fix this problem with a annual service kit.
Feb 26, 2013 | Scubapro MK17/S555 Regulator
Problem E 6 comes up on my uwatec smart com
I have a smartcom very nice dive computer this issue can ONLY be repaired by scubapro themselves the smartcom is obsolete they will give you trade dollars toward a galleo or luna which are better dive computers
Feb 05, 2013 | Scubapro UWATEC Smart Com Console Dive...
Scubapro mk 17 slow to move spg needle
the spg hose has a oriface in it so that if the hose burst you do not lose all your air underwater at once. have your scuba shop test it for proper operation.
Aug 08, 2012 | Scubapro MK17/S555 Regulator
Service
You will need to contact your nearest Scubapro authorised dealer. You can look up your nearest dealer from the main scubapro website. Most Scuba shops that undestake servicing will be able to sort this for you as scubapro is a worldwide brand.
Oct 03, 2010 | Scubapro MK2 Plus/R295 Regulator
Hey guys, im confused... i want to buy my new diving gear and i have come to a conclusion between two packages... these are : Scubapro : 1st stage din/int Mk17/395 reg + Oct R295 + seac sub BCD (First) +...
Denx7d could have not said it any better i have about 1300 dives on my gear and still in good shape and have annual service on my gear now i am a certified repair technician for scuba pro these regulators they sell are the best on the market hands down
Jan 21, 2010 | Scubapro MK11/R395 Regulator SCUBA...
I need to strip down my s555 regulator to find
Check here:
http://www.frogkick.dk/manuals/scubapro/Manuals/2.%20Stage/
May not have exactly your model, but something very very similar. Also, keep in mind, the second stage will free-flow as an "overpressure safety" if the first stage is malfunctioning. Check your intermediate pressure (should be ~150). If you can't do this, try your second stage on another first stage (any brand), and try another second stage on your first.
If it is for sure your second stage, check for proper adjustment of demand lever, bent/damaged demand lever or diaphragm plate, or damaged valve seat.
Jan 18, 2010 | Scubapro Service Diagrams Scuba Regulator...
Anyone know where I can get a Scubapro repair guide for the R295?
check here: http://www.frogkick.dk/manuals/scubapro/Manuals/
Jan 16, 2010 | Scubapro MK2 Plus/R295 Regulator
With inhalation there seemed to be a brief stop in the air stream and some resistance. This happens regardless of how my second stage is tuned. I have had two other divers to try it and they both felt it...
Is this reg new by any chance??
Or perchance it's due a good service?? Sounds like something is sticking inside..
Alternately, I had a similar problem with my mk25 just after I bought it. The dive center I was in were able to fix it overnight for me so I the weekend wouldn't be a washout and the said afterwards that the problem was one of the seals/valves inside that was a bit of a design flaw. They knew about it and had replacements on hand so it could be worth letting your local service center look at it and see what they think..
It's possible this is it too..
Sep 27, 2009 | Scubapro MK17/X650 Regulator SCUBA...
Possibly high intermediate pressure. slight second stage free flo
It is a HORRIBLE idea for you to dismantle your first stage. It should only be done by a trained technician because of how many small parts there are... now depending on your regulator you might have the ability to turn down the pressure... read the manual to find out if your reg has this adjustment capability.
May 14, 2009 | Scubapro MK17/X650 Regulator SCUBA...
Scuba Diving & Snorkeling Logo
397 people viewed this question
Top Scubapro Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Tom Chichester
Are you a Scubapro Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
