Samsung BD-P1500 Blu-Ray Player Logo
Adam Phillips Posted on Mar 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Load issue - Samsung BD-P1500 Blu-Ray Player
Anonymous
Level 3:
  • Samsung Master 6,771 Answers
  • Posted on Mar 18, 2012
Anonymous
Samsung Master
Level 3:
Answers
6771
Questions
0
Helped
1778055
Points
21413
If you are talking about the blu-ray disc not playing, try a regular DVD, if okay! the laser pickup assembly is the problem because more precision and speed is required when watching blu-ray. But if you are talking about a loading bay issue, this is a job for a professional.
Source Front loaded SWG5800.
It's possible that your front loaded washing machine is experiencing an unbalanced load or there could be an issue with the motor or drum bearings. Here are a few things you can try:
  1. Check the load: Make sure that the clothes are distributed evenly in the drum. An unbalanced load can cause the machine to shake and stop mid-cycle.
  2. Check the shock absorbers: If the shock absorbers are worn out or damaged, they may not be able to absorb the vibrations caused by the high-speed spin cycle. If this is the case, the machine will need to be repaired or the shock absorbers replaced.
  3. Check the motor and drum bearings: If the machine is making a loud noise or is vibrating excessively during the spin cycle, it's possible that there is an issue with the motor or drum bearings. This will require a professional repair.
  4. Check the control board: If none of the above solutions work, it's possible that there is an issue with the control board. This will also require a professional repair.
If you're unsure of what the issue is or how to fix it, it's best to contact a professional repair service. They will be able to diagnose and repair the issue for you.
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Why do I always have to shuffle my load to get balanced enough that it will spin full speed
From your description I would lean towards a suspension issue, If it was an electrical issue, rearranging the load would not change the way it operates.
When washing towels the load starts banging...not overloaded and repair service can't find the issue.
sounds like a broken shock,or balance spring!! possibly loose concrete weight on tub
2answers
Error 45.1.03 for t770
switch off the machine, remove paper and spindle of both roll & 2, close the roll covers, switch on the machine wait until ready mode appears, select load media, select roll 1. Load spindle in in the bank, verify properly seated or not, insert paper to load wait to printer perform load media..if successfully loaded issue closed..:Other services are not advisable to users only professionals can resolve the issue..
Screen slow to load
Its not an issue with the monitor, it can be a software issue or the computer's issue. You can also try updating or reinstalling the graphics card driver. As per your question i feel that apart from your management software the monitor is working good with other softwares, so its not a monitor issue.
All the best.
Regards,
Shrey
S-4054 will not load at start up tries to and then shuts down
It's an Issue with booting files.... re-installation of Operating system will only resolve your issue...
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
