SOURCE: how to enable bluetooth
First of all you need to connect bluetooth device to the laptop because most Acer laptops don't usually come with bluetooth device but they have the software/driver that will make bluetooth to work on it. So, I will advice that you get an external bluetooth device connect it to your laptop, the bluetooth application will make the bluetooth device to work. Thanks
SOURCE: I have an acer Aspire one d250 and I dont know the
Here is the link for the service manual, check out page 113, it goes over the procedure for jumping the motherboard and clearing the Cmos.
http://tim.id.au/laptops/acer/aspire%20one.pdf
SOURCE: Acer Aspire One D250 - Weak network signal
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply).
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
SOURCE: how to enable the camera of acer aspire one D250?
You can either use Skype or download the driver from Acer, if you dowload the driver it shoul put an icon on your desktop
SOURCE: ace aspire d250 wireless switch is not working
Read these carefully and do as the manual describes..
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
When I installed it the sound stayed tinny & became very choppy when watching video on Windows Media Player. Thanks for the idea anyways
