Purchase 2004 change bulb color wheel fly back already if got to use vcr for tuner to save money first dlp i purchase its in outdoor patio live in hawaii no snow
The DLP does not have a flyback but if rear inputs work hook cable b o x there via audio/video cables or use a VCR (does not have to play tapes) via its av jacks to one set on back of tv.
If Video rear inputs are good but antenna,coax are not B Y P A S S the problem.
Testimonial: "will try later got to buy vcr later thanks alot"
SOURCE: I have an RCA model
The color wheel can make a whinning sound for sure, However it should not continue to whine after shutting it off. That sounds more like the fan used to cool the lamp, as that will continue to run after the set is shut off. How soon does the whinning start when you push power? Let me know I should be able to help you out. DLPs are my specialty
SOURCE: How to change the color wheel of Samsung HL-P5063W
Look on Youtube for samsung color wheel. you should find your answers there...
SOURCE: How do I change Part #267888
Go in through the front of the TV behind the screen. From there you remove the light engine cover which will expose the color wheel. Take out the two screws that hold the color wheel in place and disconnect the two wires. Put the new color wheel in and re-assemble your TV.
It's a very easy job, there's just a lot of screws that hold the screen to the TV so don't lose them. Also there are four clip in wire's that you will need to disconnect from the light engine cover, so make a note of were they go before you unplug them.
SOURCE: 50" RCA DLP color wheel replacement procedure
Mine started to howl last year, I sprayed out the motor using carb cleaner / lubricant. Its been running fine for over a year since.
My guess is, the bushing gets plugged with dust particals. If you catch it as soon as it starts to squeek, the carb cleaner trick may work for you too.
pick up hln617w1 for 20.00 bulb and color change within 1year new proplem picture upside down and black picture whenbulb is on
Not good news---issue here is with either the DMD board or light engine(the board is part of the engine and alone costs almost as much as a replacement engine that comes with both(about 500)
Hawaii? moisture may have got it!
I am in San Diego and same issues there.
