Error code c3200 for solustion
SOURCE: C3200 ERROR IN FS-1118MFP PRINTER WHAT I DO FOR
I've cleaned the optics and the error stoped.
In addition, I've set U087 to no.
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
SOURCE: HOW CAN I RESOLVE ERROR c6000 in fs 1118
This might take some doing reseting the fs 1118 but it can be done if the fuser only got hit by a powersurge or overheated due to paperjam by the fuser...
press system menu/counter
select service settings via up and down cursor keys
now while pressing start key and # key press enter
then select maintenance mode by using the up down cursor key
press enter
enter 163 and then restart the copier...
sometimes you wont even be able to get to the service mode...
open the front of the copier and then execute the steps... the front meaning the area where you the toner is located...
trying keeping it open and do the steps...
if that fails then open it take out the toner drum cartridge and then put it back in...
then do the steps...
if it still doesn't take try it a couple more times...
if it still doesn't take.. buy a new fuser...
but it should take... it just takes a little experimentation...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
SOURCE: KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
error code c3200 for solustion
