SOURCE: HELP MY LIGHT DOES NOT WORK AND MY WIFE HAS CUT ME OFF UNTIL IT DOES
if its a 2 wire switch if you jump the 2 terminals together on the switcht plug the light should come on if it does replace the switch
SOURCE: whirlpool icemaker stopped working
My icemaker has not worked for years. It has been so long I got used to not having ice. I have more time this month and decided to figure out the problem. I replaced the old water supply from copper tube to a 10 ft. stainless steel flexible tube from HomeDepot. This did not do anything. I saw somwewhere about using a blow dryer to the tube that dispense water into the ice tray. IT WORKED. My wife is happy.
SOURCE: whirlpool ice dispenser not working, but water is
There are three common problems with icemakers:
There's no ice
Small or too few ice cubes
Specks in the cubes
Note: If your repair problem isn't listed, click here to email the RepairGuru. He will give you the help you need.
There's no ice
If your ice maker has stopped producing ice completely, check these, in this order:
If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
Specks in the cubes
If you find black or gray specks in your ice cubes, have a look at the ice cube tray. If the protective coating is peeling away, the most economical solution is to completely replace the ice maker.
SOURCE: Whirlpool Gold Ice maker doesn't work
You definitely have something wrong with the ice maker if the water has turned to ice Schmerold. And the IM is not harvesting. The way it works is the IM needs 28 degrees F to harvest. If the coils below in the condenser are dirty the IM won't try to harvest. The Ice Mold thermostat is mounted on the firewall of the Ice mold in its own little cubby whole. To access it you will need to remove the head. Then remove the shell separating the Ice mold from the heads housing. There you will find the ice mold thermostat. It's only function is to get it on. If the temperature is right in the freezer. To test this precious thermostat one needs only to stick it into a freezer and let it hang out for an hour or so. Then grab it and check it for continuity. If it is open it has failed and belongs in the file 13. It is easily replaced and inexpensive.
On your model, ice maker operation is controlled by an optical sensor mounted on both sides of the freezer liner. The usual failure of this model is a bad emitter board, located in one of these recesses. You may view the service instructions for checking this sensor.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. [email protected] click on link below, Thanks, Sea Breeze
I will also send free manual for you through email. And Rate my assistance.
http://servicepartstec.blogspot.com/
SOURCE: Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
