Power supply issue most likely bad capacitors you can get replacement power supply boards or repair kits from www.tvrepairworld.com
SOURCE: power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
SOURCE: 19'' Dynex TV does not come up as a Computer Monitor.
I had this same problem with the 19" model as well. I had to reinstall video driver with the tv hooked up in order for the resolutions to work properly. In order to do this I used an S-video cable which worked well enough to reinstall the video driver. I did not try safe mode which might have been easier, I just did not think of it at the time. With the video driver reinstalled while the TV is attached to my computer, I know enjoy a crisp 1440x900 screen resolution. Hope this helps.
SOURCE: 32" Dynex No Power, Power on/off light will not light up
Check the power supply module first for blown fuse, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
SOURCE: Dynex TV will not turn on, red light on as usual.
The standby 5vdc is working but not the rest.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Parts: www.shopjimmy.com
