Hi there is something wrong with my camcorder,when me and my friend were getting ready to make a video i pressed record and it said CARD PROTECT.my friend fixed that but when i started to record it started lagging and then when i stopped recording i shut the camera screen.then when i opened it it wouldnt let me do anything it would just stay at the recording screen.it wont let me look at my old videos,record,or do anything so i need help very much please!!! my friend got this camera just a couple days ago so please help!!! thank you
SOURCE: Help!
The same thing happened to me and i don't know what to do either but as i was currently researching it i found a solution that when you were editing it or putting it on the computer an issue accured that you pressed something that makes you not able to delete, record, or take pictures....
SOURCE: Unable to get images and vidoe off SD card
I have found that you almost have to download your pictures directly from the camera with the SD chip still in it. Don't know why you can't take the chip out, like with other media. As I recall, the manual says to download from your camera. Sorry.
SOURCE: card protect
For some reason, the SD card in your camera is being viewed as write protected. There is a small "switch" on the SD card that slides. Slide it up and down a few times and try it again. If that does not work, here is the solution that worked for my camera. Place masking tape (opaque, used for painting) over both positions of the switch. I had to put 2 pieces to make it inflexible. Be sure not to get tape on the metal contact points. I hope this works for you. It fixed mine, although I don't really understand why. If this doesn't work, try a new card.
SOURCE: Problem viewing video on computer
I called the phone number listed for Aiptek support ...they helped me work through the problem
