I need to replace my old battery with a new one, how do i get the old one out?
Remove the battery box compartment cover. Disconnect the positive and negative battery leads. Undo the battery holding down clamp screws and remove the battery clamp, now you can lift out the battery.
Place the new battery in the battery box and secure the battery hold down clamp. Connect the battery leads to the battery, the red lead to the battery's positive terminal and the black negative lead to the battery'e negative terminal, then replace the battery box cover.
O.K i just replaced mine.1st remove the pillion cover,then undo four alan key screws holding the tail section on (two on top and two either side)Then remove one bolt that holds the light cluster on at the back of the bike Below the brake light)The whole section slides back and the battery is exposed.This was done gently so as not to break plastictics.
