if you tries to turn it off and it turns back on after a few seconds.the birthda reminder in a contact record that spans past the new year (jan1)will trigger this.palm is aware of this paricular issue which is peculiar with the devices tungsten T3,T5*,E*,Ttreo 650* etc
for example if you create a contact record for a person which includes his/her name,phone number,adress and email adress.you also include his birthday,jan 2. you then choose the reminder to appear 7days before his birthday since this reminder will be triggered before january 1,the hand held may encounter problem not turning off.
solution
- set the calendar to go off in the same calender year as the birth day(i.e on or after jan1)
- in the example above changing the reminder to 1 day will prevent the issue
- to change birthday reminder:open contact applicatio>open the record with the birhday>select edit>scroll to the birthday field> tap on the birthday>change the reminder.
- like in the example above ,you change the number of days to 1
- alternatively simply uncheck the birthday reminder box in order not to be reminded at all instead of changing the days if you dont want to be reminided at all.
