I have just installed the game on windows Vista and at first it would not boot so went into properties and set to run as administrator. It now boots but only to the initial resolution options "World War III Setup" and will not let me go any further. I select a resolution for the game (tried a few) and tested but then when pressing "ok" nothing happens. The "ok" button doesnt even get grey'd out
SOURCE: during installation I got an error 533 code and it
Try right clicking the install program and choose "Run as Administrator"
SOURCE: I have a new computer
Yep. Compatibility. But there is hope. Find the game icon. Right click it and click Properties...
Then click Compatibility.
Once there check on 'Run as Administrator', then Ok.
Try it again. If it still doesn't want to work then go back to the same windo and click 'Run Program in Compatability Mode for...' and select a previous version of Windows (XP SP3 for example). If that don't work push it back a little further and further until you find one that works.
SOURCE: I have a problem with
I had the same issue and resolved it by downloading the World war 3 black gold 1.2 Patch - install this and you should be fine. I will still ask you to select a resolution but it will actually let you now.
I got mine from here
http://www.shacknews.com/file/454/world-war-iii-black-gold-12-patch
Ive managed to find a fix for this and I can see a number of people are having the same issue. I the game wont boot at all but has installed then right clicking the WW3 Black gold icon, selecting properties=>compatability tab and then selecting to run as administrator does resolve that issue so thanks to Bryan D for that one!
But if the game does begin to boot but you get stuck on trying to select the resolution type and cant get use the ok button then download the World War 3 Black Gold 1.2 Patch and install it and this should resolve the problem.
I got my download from here http://www.shacknews.com/file/454/world-...
Yeah okay, so I down load the patch..wht program do i use to open it with?
1.2 patch worked for me .. thanks
