Question about Exercise & Fitness
Stairmaster quinton 612 plus error code e201 - Exercise & Fitness
Sportsmith LLC
  • Exercise & F... Master
  • 918 Answers
Quinton Error E201 Probable Cause Grade Over Limit Fault. Turn jackscrew counter clockwise to get within range.
Corrective Action
  1. Use Up or Down arrows to bring grade into range.
  2. If error persists, replace grade actuator or VSD. NOTE: Belt and display may continue to be used during fault conditions by pressing clear.
Quinton Treadmill Error Codes E201
Posted on Feb 04, 2015
1 Related Answer
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: I have a Quinton Clubtrak Hyperdrive treadmill.
E 201 is power interruption if you are using it and it trips the breaker I would loosen the belt make sure you count how many turn to loosen belt and write it down so if you tight back up you would put the correct tension. check the belt and deck they maybe worn if it has worn thru its black phenolic deck then replace it.call National Gym Supply @ 1-800-496-7278
Posted on Mar 02, 2010
Code e207 stairmaster club track
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
E207 is an error indicating "Moderate Motor Overcurrent". This occurs when either the user is out of the maximum weight range or there is excessive wear on the deck or running belt. The following link will take you to the parts and other information we have available on the club track.
Stairmaster Quinton Treadmill ClubTrack 612 612 Parts SPORTSMITH net
Jul 08, 2013 | Exercise & Fitness
Quinton treadmill E203 error VSD Lower Board
Quinton E203 Error, Motor Overcurrent (Overload) Probable Cause 1. Obstruction to motor pulleys or belt
2. Disconnected or loose motor lead
3. User outside the weight/speed envelope.
4. Excessive wear to deck/belt.
5. Motor.
6. Lower Electronics.
Corrective Action Quinton Treadmill Models: Club Track 3.0 and Hyperdrive
  1. Inspect for obstruction and remove if necessary.
  2. If the motor did not turn, inspect for loose or disconnected motor lead. Reconnect if necessary.
  3. Restrict users to weight capacity of unit. Restrict use to people that do not move slower or faster then speed setting.
  4. Inspect deck and belt condition. Deck should have a slick smooth surface, free of nicks, grooves, or rough areas. Deck should be flipped or replaced if necessary. Underside of belt should not have a hard glazed appearance. Belt should be replaced when deck is flipped or replaced.
  5. Club Track 3.0 models: Remove power and allow unit to cool for 15 minutes. If unit operates and then error appears again, replace drive motor.
    Hyperdrive models: Remove power and wait for high voltage indicator to go out. Check resistance between motor leads. If the reading is greater than 100 ohms, the motor needs replaced.
  6. Club Track 3.0 models: Remove power and allow unit to cool for 15 minutes. If error message appears immediately, replace the lower electronics.
    Hyperdrive models: Remove power and wait for high voltage indicator to go out. Check resistance between motor leads. If the reading is less than 100 ohms, replace the lower electronics.
Quinton Treadmill E203 Error Code
Feb 20, 2013 | RTO Stairmaster Clubtrack 510 Treadmill
E203 error message when i press start button
5. Motor.
Jan 09, 2013 | Exercise & Fitness
Corrective Action
Mar 16, 2012 | Startrac Fitness Products Exercise &...
Quinton clubtrack treadmill shows E203 code, says drawing more than specified current. Could it be a bad motor?
5. Motor.
Dec 06, 2011 | RTO Stairmaster Clubtrack 510 Treadmill
I have a quinton clubtrack treadmill with an E105 code
E105 means power interruption if this is a 3.0 or Hyper Drive just need to hit clear or start that should take of code until either it is unplugged another power outage
Mar 02, 2010 | RTO Stairmaster Clubtrack 510 Treadmill
QUINTON CLUB TRACTURNED MACHINE ON..THOUGHT IT WAS 220 VOLTS..SAW
This is most unfortunate if this either club track 510 or 612 your out of luck the electronics are no longer available. If these are either 510 or 612 you can get it repaired call National Gym Supply @ 1-800-496-7278
Jan 29, 2010 | Exercise & Fitness
I have a quinton club track treadmill that posts an E203 error
E203 = Motor unable to run. Usually caused by the VSD Lower Board. This board is about 14" square on a Quinton Clubtrack Hyperdrive 3.0
Rather difficult to remove escpecially if your not familair with electronical compnents in a tight space.
My reapir coast $374 from J&R Technical Services and exactly one year later I got the exact same code. Warranty is 90 days.
It appears they rebuilt one of the components on the board called a Phase Modulator. There are three of them. They stated they had replaced it, but upon close inspection it appears that simply replaced the bad micro-component on the modulator and reinstalled the exact same phase again.
I'm debating whether to trust them once again. Little choice though since they control the market and have the equipment to reset the board upon repair. Nobody at thome has this equipment.
Sep 15, 2009 | RTO Stairmaster Clubtrack 510 Treadmill
I have a Quinton Clubtrack treadmill Error E105 NVRam Failure
fax me @ 281-469-9550 your full model number and I can fax you the setup modes.
Jun 27, 2009 | RTO Stairmaster Clubtrack 510 Treadmill
Exercise & Fitness Logo
183 people viewed this question
Top Exercise & Fitness Experts
Tom Chichester
ray gallant
Marvin
Marvin
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
