Question about Coship CDVB2000E
How can i use cdvb 5668 to view free to air channels
Posted by yahya amin on
Eu Flo
    New Friend:
Can Coship/Echolite CDVB 5668 be converted to a FTA receiver?
Posted on Apr 30, 2018
daniel
    New Friend:
How to ears previous FTA channel & edit new Give detailed step-by-step instructions
Posted on Dec 17, 2012
Scramble channel on my tevion vision hdsr 600
When you first scan either auto or manual it should ask if you want FTA or the entire channel list.some on the full list are scrambled and are pay for view.if you just want free to air then rescan manually and this will remove those channels that are scrambled.
Nov 10, 2015 | Vision Televison & Video
Why is channel manager option grayed out?
Channel manager may not be an available option for over-the-air viewing
Jan 27, 2014 | Hitachi 42 in. Plasma TV
My tv's freeview wont let me view any other channels apart from the bbc
Freeview? I'm not good with tv words... Is freeview a free channel you stole from the neighbors dish (don't be ashamed)? If so, then you should buy cable (Cable's better. Really. Satellite dish companies looked one thing over. Storms ruin your tv.). If your just watching what you can get through the air, well, that won't work. After a while, you start to lose channels. Just get cable. If you already have a tv network, then you should call the tv company.
Jun 18, 2012 | DMTech DM-AV10 Digital Media Player
I have lost all my freeview channels on my samsung tv how do i get them back?
When you say free view i assume you mean all the free to air digital channels?
Simply make sure you have good reception and do a channel search and you should gain all the free to air channels, including digital channels if your tv has a built in set top box. Good luck.
Sep 04, 2010 | Televison & Video
Unable to tune free view channels........... help !
Get a better Antena,like digital antena or a roof outside Antena to get better reception.Go to ur tv menu goto SETUP pick AIR and scan all the DTV free air programs stations.
Jul 06, 2010 | Dell W3706MC 37 in. LCD HDTV
How do i get my funai vcr to record from my freeview box. I can only record through my analogue channels. I have a funai vcr either 31B-750 or 31B-754 (PDC) and the freeview is an Astratc TopD2
hi, how is the free view running through the video?
Option 1(this is the most complicated way if you are using scart lead or the three color leads then skip to option 2)
if you using the normal arial socket ie arial from roof goes into free view then from free view into vid then vid into tell then what you need to do is make sure on the free view that you have a menu screen on the screen either tv guide or something that will stay on their.
Now put the video on a channel you dont use say 6 then you need to use the video remote and then enter the setup mode and then start the scanning process to look for the signal keep going until you get the menu screen that you opened on the free view then store this as channel 6 on the video.
Now when you want to record from the free view you put the video on channel 6 and put the free view on the channel you want to record.
Option 2:
If you free view box is using scart leads and has two scart lead outputs on the back, ie one for the telly and the other for the video, if you have it like this then plug telly scart into telly and video scart into video.
Now in the back of the video you should have scart lead coming from the free view, and maybe one coming from the video into the telly
If this is the case then all you need to do to record off free view is switch the video on the when you choose what channel you want to record instead of choosing 1 to 5 for normal channels you need to select av scroll down the channels past zero if you have not got av button once av is selected you should then see the free view channels try by pressing guide on the free view and put the video on av this should then let you see the free view via video if not dont worry press record for 5 min then rewind and press play it should now play back the free view you was just watching.
Option 3 now if you have it set up any other way just let me know how then i can assist you further ok.
If you have any problems following my instructions then just post me a message back and ill be glad to assist you further ok.
Many thanks for using fixya.com
Nov 18, 2009 | Electrical Supplies
No channels just green lights on free view box
go to menu settings, make sure it is on air or CATV depending on what you are using. CATV is for cable or dish.
Then go to menu settings and find the "autoprogram" option and select it. It will scan any available channels. Let it run through completely.
Oct 01, 2009 | Durabrand DWT1905 TV
How to get all freeview channels-all i get is the first 5 channels
Go to menu, find "autoprogram" setting and select it. It will scan all available channels
Aug 17, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Star view box will only display free view channels, what do I do?
HAVE YOU SORTED YOUR BOX OUT? IF NOT LET ME NO AND ILL TALK YOU THROUGH IT
Jun 27, 2008 | StarTech.com StarView SV211K 2-port KVM...
Televison & Video Logo
476 people viewed this question
Top Coship Televison & Video Experts
Marvin
Marvin
Are you a Coship Televison and Video Expert? Answer questions, earn points and help others
