Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Mitsubishi WD-52725 DLP DM board
DM board?
Posted by Darin Wilson on
Sonny Berry
  • Mitsubishi Master
  • 8,617 Answers
The DM boards for that chassis are almost impossible to find if they are still good. Have you tried replacing the caps on the DM board that you have? Thats usually whats wrong are bad caps.
Posted on Mar 16, 2012
Testimonial: "Hi. Thanks for the info. I did find one cap that domed and replaced it. Not knowing that you had to wait and hit a reset button. I ordered 12 caps that are mentioned in other posts. We'll see what happens then. Thank you again."
E TIPPINS
    New Friend:
Email me back [email protected]
Rebuild by Mitsubishi whole module ? DM module part # 955B298001
Posted on Nov 27, 2012
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: WD-52725 Timer light is blinking and will not stop.
This part will cost you about 650 to 800 bucks my friend. if you have any soldering skills, and can follow directions, I posted a DM board fix. it may just be four small capacitors. Now this set that was used in the fix is not exactly like all the other Mitsubishi TV sets that still have a DM board, but if you can locate the DM board, follow the rest of the repair. if you do not know how to solder, do not take a chance, as this part is way too expensive to be experimenting around with. Get the Capcitors(there is a link there too for the capacitors)and take the DM board to a service shop, as this should not cost you a lot to have a pro do this for you. The DM board fix is located here: http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Good luck
Posted on Jun 29, 2007
Anonymous
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
Jim Krause
  • 1779 Answers
SOURCE: Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Posted on Feb 14, 2009
electroman
  • 1039 Answers
SOURCE: mitsubishi wd 52725 lamp troubles
You can use Mitsubishi 915p020010 or Osram E023. Remove the front and clean the lense using only a clean microfiber cloth. dirty lense main cause of dark picture. The lamp could be incorrect wattage.
Posted on Apr 25, 2009
Anonymous
SOURCE: Mitsubishi Model WD-52725 timer green light blinking fast
My Mitsubishi WD52725 will not turn on...the timer light is blinking. We pushed the reset button, unplugged tv. Just got off the phone with Mitsubishi customer "service." After answering numerous personal questions, and being on hold for several minutes, I was told that the only solution was to push the reset button. Duh! We'd done that several times with no change, which is why I called them! BIG WASTE OF TIME!!!!
Posted on Jun 19, 2010
1helpful
2answers
We replaced the V26 dm repair kit and the problem still exists-tv won't turn on . What do you recommend?
Did you also replace the power capacitors on the power board. Usually the DM board and Power board caps together will cause the steady blinking led the DM caps alone only rarely cause the steady blinking led usually its a combination of both boards capoacitors failing.
2helpful
Green timer light flashing set is not on
The V26 chassis dlp DM repair kit usually fixes that issue. The kit contains the capacitors and detailed instructions on CD. You can get the repair kit at www.tvrepairworld.com
Timer light blinking green
you need the repair kit for the DM you can get the kit at the following link whic contains the capacitors and step by step instructions on how to do the repair
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-dm-pwb-repair-kit/cName/repair-kits
Green Light Under Timer Stays Flashing and Will Not Go Out
Mitsubishi has repaired some sets if you have the origional purcahes documents. If not you can get the v26 DLP DM repair kit which should take care of that issue. Heres a link to the kit if needed.
1helpful
Mitsubishi DLP wd-52725 wavy lines from top left to bottom right
the DM board is going bad and needs to be rebuilt. check out www.tv-techs.com
Need DM or FMT PC board
If the front light of the TV is blinking green suspect caps are bad and change them yourself, google for cap locations
1helpful
8answers
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
