HI THIS SET BELONGS TO A SICK LITTLE BOY FOR HIS VIDEO GAMES i am trying to fix for them they dont have much money here is what i have the set turns on but does not fire up i have the lights on the power supply on the right hand side of cabnit and on red led on botttom board on the left by jacks i hear relay click and then the red led goes dim then out i tried to test the convergance chips by unplugging the load that did not help i suspect the horz output i get a reading on all legs to heat sink can any one shed light on this i would greatly apprecate it thanks
SOURCE: Pulsating power LED. No picture. No sound
Either the main smoothing capacitor or the voltage regulator are faulty. You may find that the power LED will stay on after pulsating for several minutes, at which time you can switch the TV on.
SOURCE: Hitachi 43FDX01B convergence red line wont move
probably need to replace STK IC on convergence board and possibly associated low value resistor
SOURCE: 53WUX10BA no power/sound/video but power light is on.
With KG02 removed, the short lies in B+ 115 V1.
SOURCE: HITACHI 50UX10B AP23 CHASSIS NO POWER
please check all the lights that are in the chassis hitachi puts led in the chassis so that if one of the lights are not working then u know that circuit is bad. now there is 2 things that hit has wroung in the units and that is a 2kv hv cap of the horiz output transistor that burns up and kill the power supply look for a small black or brown fuse it will not have glass on it it is rt behind the reg ic in the center of the chassis it allwas opens up because of the hv cap doonot run the tv without out that cap it will overload the horiz drive and will burn upo the horiz output but u have a very good ctv ther if u fix it will last u a long time and it is a very easy tv to trouble shoot.
SOURCE: TV Want Power up
This tv have different causes for no power.
Can you tell me if any light on the chassis is off?, if so, let me know the location part number.
Common problem is IC output ( short) or convergence STKs ICs.
Thank you
