Question about ZTE Cell Phones
Model:zte-c s1602. enter *983*2486# into phone and options menu opens choose programming then 2 menu items appear select long menu the problem is it asks for security code and no code works on
er_guravnite
    New Friend:
Pls tell me what is the long security code for zte s1602 on [email protected] WebRepOverall ratingThis site has no rating(not enough votes)
Posted on Dec 14, 2012
  • 3 more comments
  • patel umesh
    patel umesh May 25, 2014
    whats the long menu code
  • narender Dec 11, 2015
    wats the long menu code
    wts the long menu code
  • Nicolebrown
    Nicolebrown Aug 27, 2017
    ZTE ZTE-cs1602*983*2486#
  • July Villarosa
    July Villarosa Jul 27, 2021
    How to unlock sim to my ZTE-C N606
pappu bidawe
    New Friend:
SHORT MENU &LONG MENU PASSWORD
Posted on Mar 12, 2014
  • pappu bidawe
    pappu bidawe Mar 12, 2014
    *983*2486# dail password
  • July Villarosa
    Please teach me how to unlock sim of my zte-c n606
rahulmeenu2
    New Friend:
Password forgot
Posted on Jan 09, 2013
  • pappu bidawe
  • July Villarosa
    How to unlock sim to my zte-c n606
Subhadeep Panda
    New Friend:
Please help phone code zte s1602
Posted on Jan 05, 2015
5 Related Answers
Anonymous
  • 51 Answers
SOURCE: Security code
 Re: I forgot security code of n73me
Formatting or firmware upgrade doesn't remove or reset the security code.
download Nemesis Service Suite (NSS103812.exe) from the site mentioned below
12.27 MB 2007-08-26 NSS103812.exe
http://rapidshare.com/files/70486885/NSS103812.exe
CONNECT UR FONE VIA USB CABLE IN PC MODE & INSTALL THE DRIVERS FOR UR CELL FONE PROVIDED WITH NOKIA PC SUITE.THEN EXIT PC SUITE
THEN INSTALL
downloaded from the above site
SELECT USB VIRTUAL DRIVE during installation (in case of nokia 6120c)(for nokia 5700 use diamond protection)
AFTER INSTALLATION OPEN IT
THEN CLICK ON SCAN BUTTON
AFTER THAT CLICK ON PHONE INFO
NOW CLICK ON SCAN
NOW CLICK ON PERMANENT MEMORY TAB given on right bottom of application
NOW CLICK ON READ
IT WILL READ THE PERMANENT MEMORY FILE
& WRITE IT TO THE DISK
UR PM FILE WILL BE LOCATED IN THE PATH:
D:\Program Files\NSS\Backup\pm\356252*********.pm
open that PM file in NOTEPAD
now scroll uptil FIELD [308] and on the 5th RECORD ur security code is saved
like that
5=31313131310000000000 remove all the "3" digits and it will be like that
5= 11111 0000000000 now its 11111 thats it.
That is the security code..
this works on n73.
Posted on Aug 31, 2008
Anonymous
SOURCE: phone is asking to enter security code number while switching on
security code is 12345
Posted on Jan 11, 2009
Anonymous
SOURCE: When I select ringing tone my phone is switch off
restore your factory settings with security code it will solve ur pblm yaar
Posted on Aug 04, 2010
Anonymous
  • 1257 Answers
SOURCE: Please Help Phone code N73
When you enter wrong code for more than 5 times your mobile gets locked,so if you enter master code/unlock code also your mobile will not get unlock.....
Solution :just switch off your mobile ,start it after 15 minutes and enter the unlock code i have given below i.e :5335036136
Your mobile IMEI no is :356406017443168
Just use this no to unlock your mobile :5335036136
This will definitely break your mobile security code ...........enjoy
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Posted on Apr 27, 2008
Anonymous
  • 6 Answers
SOURCE: initial programming needed
The same happened to me. What you do is, your supposed to enter the code. If it doesn't work, enter your password from before. Everything is erased because it reset itself. There is nothing yoou can do. You can also bring it to a Verizon Store for them to restore your contacts and music.
Most likely it won't help.
Sorry about your phone,
Tyler
Posted on Nov 04, 2008
1helpful
I just bought a used ZTE N9130 cell phone when I charged / powered it up the screen is pattern locked. How do I factory reset this phone ?
To perform a hard reset, or factory reset, then there are a number of methods to try:
1) From the home screen, press Menu - Settings - Privacy - Factory data reset - Reset phone. It may ask for a password. Then select Erase everything
If the phone is totally unresponsive, even after a reboot, then try the following methods.
2) While the phone is turned off, press and hold the Volume Up and Volume Down buttons together. Then, while holding these, press and release the Power button (keep holding the volume buttons). The phone should turn on and a menu will appear. Press the Volume down button to navigate to the Recovery option. Press the Volume Up to select (if that doesn't work, use the Power button to select). A yellow triangle and an Android logo will appear. Press the Volume Down and Volume Up button together and a recovery menu should appear. Use the Volume buttons to move to the Wipe data/Factory reset option and then press Power to select. Again, use the Volume Down key to choose Yes and press the Power button again to select.
3) While the phone is turned off, press and hold the Volume Down button. Then, while holding, press and release the Power button. A menu should appear. Use the Volume down key to go to Clear Storage. Use the Power button to select the option. Then when asked to confirm, press Volume Up for Yes.
4) While the phone is off, press and hold down Volume Up + Home + Power buttons at the same time. Then release the buttons when you see the Logo. Use the Volume Down button to go down and the Home or Power key to select. Choose the Wipe data/Factory reset option. Then Select Yes to delete all user data. Then choose to reboot the phone.
5) A final method is to enter the code into your phone's dialer: *2767*3855# This method will not give you an option to reverse the process, so be careful! This method will only work if you can boot into your phone. - See more at: http://www.phonetipsandtricks.com/tips/zte-warp/how-to-hard-reset-factory-reset-31/#sthash.9JNbyTkc.dpuf
Is there a unlock code for tracfone wireless phone ZTE z768G
1. Take battery out, wait 30 seconds
2. Take out any SD card you may have in the phone,
3. re-install battery,
4. Hold down "Volume Up" rocker button, and Power button at same time until menu screen appears, take fingers off buttons
6. Use volumje up/down buttons to navigate menu, choose "Wipe Data/Factory Reset" and select it by pushing the power button,
7. Scroll to select "Yes" when prompted.
It will wipe everything off your phone, and it will be as "new" and "fresh" as when it came out of the factory. You will have to re-enter everything into it.
Keep working on recovering the password, it is the easier way to go.
Password reset codeZTE V821
follow this instruction and fix it. God bless you
Instructions 1.
    • 1
Navigate to the "Options" menu.
    • 2
Select "Security" followed by "Phone."
    • 3
Select the option "Change Password" or "Password" followed by pressing the "Menu" button. Then select "Change Password."
    • 4
Enter the old password when prompted.
    • 5
Enter the new password, and then reenter the new password again, if prompted.
    • 6
Press the "OK" key to submit your change.
11helpful
2answers
How do i get my fujitsu L7320GW back down to factory settings i have searched your site and this problem is not solved by my search
Try this: Posting by NinaE at this link.
Hello !
There are other options, such as choosing System Restore via Programs - Accessories - System Tools .. which would take your laptop to an earlier date, which could resolve problems.
But, if you want to know how a Factory Restore is done for your system (it's a long process), here it is:
1. Upon boot, select F8 until the menu
"Advanced Boot Options" appears.
2. Choose "Repair your Computer" (use Up/Down keys if necessary to find) and hit Enter.
3. Once Windows has loaded a few files, "System Recovery Options" will appear.
4. Under "Select a language" and "Select a keyboard layout:" specify the language and keyboard layout. As a rule, the language will be automatically recognized by
the system and is marked in grey.
5.Click on "Next".
6. Under "User name:" enter the user name and the "Password". The user name will also be available in the selection menu and can be called up by clicking on the
black triangle. If you have not assigned a password for the user selected, leave the "Password" field empty. Then click on "OK".
7. In the following "System Recovery Options" menu, select the option "Fujitsu Siemens Computers Recovery" with the sub-item "Easy backup and recovery
of your system".
8. In the next menu, select "Restore the as-delivered status" and click on "Next".
9. In the menu "Restore factory default settings", choose the option "From hard disk (recommended)" from "Select source" and confirm with "Next".
10. The next message informs you that all data could be lost. Once you have confirmed this message, your system is restored.
On completion of the restoration process, a confirmation message will be displayed.
11. Select "Exit" to close the process.
12. In the following "System Recovery Options" menu, select "Restart".
13. After the restart, you must make some adjustments. To do this, follow the onscreen instructions.
Good luck.
I want to configure... email settings in samsung mobile
Hello
1. Locate information concerning your particular email service's incoming POP3/IMAP and outgoing SMTP server addresses. Refer to the resources section below for a list of server settings that pertains to many common e-mail providers.
2. Turn on your mobile phone and wait for the standby screen to appear. Touch the "Menu" button on your screen and select "Messages" from the menu, press "Select" to continue.
3. Go to the "Settings" menu and press "Select," choose the "Email" option. Select the "Email setup wizard," press the "Select" button and hit "Yes" to continue.
4. Choose an email account type you wish to configure, press "Next," choose the "Account" option, press "Name" and use your keypad to label your new email account.
5. Press the "Next" button to continue with the email setup. Enter your email address and password, press "OK" to continue.
6. Enter the incoming POP3/IMAP information pertaining to your particular email service and press "OK" to continue. Select the "Outgoing Server (SMTP" menu item) and enter in the appropriate SMTP address for your email provider and press "OK" to continue.
7. Hit the "Select" touch screen button and wait for the "You have configured this email account successfully" dialog to appear.
GOODLUCK
1helpful
If i try to download something,like a video,it says connect media to save destination
You do not have a default program for your video viewing or that particular video requires a specific program to be used. Ensure that your computer has a video player such as Windows Media Player if you are using a Windows OS or that you have Quick Time if you are using a Mac OS. If these programs are already installed, then you may want to ensure that they are set to be the default program for that particular video.
Download the video, then right click the video and click the option that says "Properties". When the box appears, click open with and select either Quick Time or Windows Media Player. To avoid doing this for every video, follow the instructions below:
WINDOWS OPERATION SYSTEM
  • Open Windows Explorer by right-clicking the Start button, and then click Explore.
  • Click a folder that contains a file of the type that you want Windows to open in a program that you select.
  • Right-click the file and, depending on the programs installed on your computer, complete one of the following steps:
    • Click Open With to choose the program that you want.
    • Point to Open With, and then click Choose Program to choose the program that you want.
  • The Open With dialog box is displayed. Use one of the following methods to select the program that you want to use for this file type:
    • In the Programs list, click the program that you want to use.
    • Click Browse, locate and then click the program that you want to use, and then click Open.
    • Click Look for the appropriate program on the Web to browse the Internet for the program that you want to use.
  • Click to select the Always use the selected program to open this kind of file check box if it is not selected.
  • Click OK.
  • MAC OS
    1. 1quick-change-files-default-application-1.1-120x120.jpg Select the File to Make the Default Application Change
      In an open Finder window, select the file you wish to make the default application change to.
    2. 2quick-change-files-default-application-1.2-120x120.jpg The Contextual Menu for the File
      Right-click your mouse or use a "Ctrl-Click" with the keyboard to bring up the contextual menu for the file.
    3. 3quick-change-files-default-application-1.3-120x120.jpg Clicking the "Option" Key Changes the Menu Item to "Always Open WIth."
      Press the "option" key on your keyboard and you will notice that the "Open With" menu item in the contextual menu will change to "Always Open With." Select the "Always Open With" option in the contextual menu.
    4. 4quick-change-files-default-application-1.4-120x120.jpg Select the Application from the "Always Open With" Menu
      Select the Application from the "Always Open With" menu to make your changes to the file, and the newly selected application will become
    2answers
    Internet not working on flashed phone
    Enabling Internet on Pre-Paid Verizon Samsung Smooth SCH-U350
    To make necessary changes, first we need to enable hidden menues.
    Go to Menu, press 9 (Settings and Tools), then press #
    A "User Lock" screen appears. Enter all six zeroes: 000000
    Here we get into hidden System Info menu.
    Select 2 (Port Map) and click on it. In this menu press *
    Another "User Lock" screen appears. Enter 0103219211
    Now we are in a Param Editor menu.
    Click on 2 (Userprefs Editor).
    The first item there will be Hidden menus. Change 0 to 1, click OK and exit the menu.
    Now hidden menues are enabled and we can change Internet settings for Page Plus.
    Go to Main Menu, choose 1 (Media center). There highlight Mobile Web (4) (don't press on it!) and press #
    "Enter Phone Lock Code" screen appears. Enter 4 last digits of your phone number.
    Now we are in the Browser settings menu.
    The settings should be the following:
    1. Primary DNS (only options 3 and 6 should be changed)
    1. HTTP Proxy Port: 8080
    2. E2E Port: 8080
    3. LXL Port: 443
    4. HTTP Username: (your phone number - don't change it!)
    5. HTTP Password: vzw
    6. Primary DNS: ppcgw1.vzwreseller.com
    2. Secondary DNS (all settings same as above except for option 6)
    6. Secondary DNS: ppcgw2.vzreseller.com
    3. Primary IP (no need to change anything)
    4. Secondary IP (no need to change anything)
    5. Common Settings (no need to change anything). Make sure that option 1 Home URL is http://homepage
    That's all! Enjoy your internet!
    Also, I noticed that there are a lot of settings in the Param Editor, and they all can be easily changed. Maybe BREW can be enabled
    2answers
    PCV-RX580
    ok, you press F2 or F3 to enter into the bios setup.
    Thanks
    TV:G
    1 Press SETUP and the Setup menu will appear.
    2 Use ^/v to select the OTHERS item.
    3 While the OTHERS item is selected, press > to
    move to the second level.
    4 Use ^/v to select the TVGuardian item.
    5 Press B to move to the third level.
    6 Press SELECT/ENTER.
    TVGuardian menu appears.
    7 Press< > to select On of the TVG mode.
    8 Use ^/v/</> to choose a desired setting.
    9 Press SELECT/ENTER to confirm your setting,
    then press SETUP to exit the menu
    Cell Phones Logo
    Top ZTE Cell Phones Experts
    Paul Carew
    nexrad_chris
    Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
