HP PROMO ELITE 7100 MT WINDOWS 7 PROFESSIONAL 64BIT  VS693UTABA (VS693UTABA) PC Desktop Logo
Johnnie L. Gillespie Posted on Mar 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i find me ssid
I have a hp, window 7 ,model, lAMD, Athion II desk top. I need to find my SSID on this computer.
Sanchit Jain
Level 2:
  • Expert 126 Answers
  • Posted on Mar 16, 2012
Sanchit Jain
Expert
Level 2:
Answers
126
Questions
Helped
38055
Points
345
Generally, SSID is a name of your network, through which you will be able to access the Internet.
Perform the following Steps
  1. Go to start
  2. Type CMD in search box and select run as administrator.
  3. A black window will open and on that type, IPCONFIG, and hit enter
  4. Overthere you will get Default Gateway.
  5. Note that Default Gateway and close that window.
  6. Open Internet Explorer and in the address bar, type that default gateway and hit enter.
  7. It will ask for username and password. In user name, try admin and in password, type password.
  8. Once, it accepts the username and password, go to wireless setting tab and overthere you will find your SSID
2 Related Answers
Anonymous
  • 51 Answers
  • Posted on Dec 04, 2010
SOURCE: I have a HP m1160n, I installed windows 7 an II
Hi there
Sorry to hear you have a problem. Did you install windows 7 as an upgrade? If so, did you run the upgrade advisor before you upgraded? If you installed it as a new clean Operating System, did you check to see if your HP m1160n has drivers that will work with windows 7? I just went to the HP website to check for your drivers but it does not recognise the model you state M1160N. Go here http://welcome.hp.com/country/uk/en/support.html and put in all the numbers of all the stickers on the case or that look like HP. These maybe serial number, part number, model number, spares number until you get a match for M1160N. Then check to see if your drivers are available for Windows 7. If they are not you will need to install seperate new audio, network and TV tuner cards that er compatible with Windows 7.
All the best, Phil
Anonymous
  • Posted on Nov 24, 2011
SOURCE: i need the password to reboot my computer an hp 2005 desk top
go into control panel and click on user accounts and just dealeat all passwerds to everything except admin
How do I find my SSID number on Acer Iconia One 7
The SSID number is the identity of the router you are trying to connect to, not your computer.
Turn on the Wi-Fi under settings and look at the list of SSID's there.
tip
How to connect to always automatically connect to your SSID
Ever turn on your computer and try to connect to the internet? Ever see all the many SSIDs in your neighborhood listed in your wireless radar or your "Windows Wireless Connection". Then you'd scroll down to double click on your SSID so that you can connect to the internet. Imagine doing this everytime you have to connect to the internet. Wouldn't that be annoying?
The Objective
The objective of this Tip/How-To is to have you turn on your computer and connect to the internet automatically via your SSID (Wireless Network Name). Hence, you wouldn't need to manually find your SSID everytime you need to connect to the internet.
Pre-requisites or Must haves for this Tip to work
  1. A computer with a wireless adapter
  2. A wireless router
  3. An active internet service
  4. This tip is designed for Windows XP. I will post one up for Windows Vista and Windows 7.
  5. This tip is designed to work with Wireless Networks (SSID) that do not have any passwords or encryption.
Active Tip Dictionary (throughout this TIP)
SSID
is the technical term for your broadcasted network name. This is basically what you will see listed in your WIRELESS NETWORK CONNECTIONS manager.
To make your computer connect automatically to the internet via your SSID, we will need to manually tell your computer to connect to your SSID and then we will need to save this setting so that your computer will automatically connect to your SSID everytime you turn on your computer.
Let's Begin.
Start your computer by turning it on.
Click on your Start Button.
Move your mouse over to Control Panel and then left click on it.
Double click on the Network Connections icon.
Double click on Wireless Connection. Now in the picture above you see Wireless Connection 3 but on your screen you should see Wireless Connection.
Now click on Properties.
Click on the Wireless Networks Tab.
Now scroll up and down under Preferred networks until you find your Wireless Network Name (SSID). For me, it's called linksys therefore I will select linksys.
Now click on the Connection tab.
Under Automatic connection, click to check "Connect when this network is in range". This will tell your computer to connect automatically to your Wireless Network Name (SSID).
Click OK to save this setting.
Click OK again to get out of the Properties window.
Click OK again to get out of the Wireless Connections window.
Then click Close to close out of the Wireless Connections window.
And there you have it, you have setup to automatically connect to your Wireless Network (SSID) everytime you turn on your computer.
Now restart your computer and give it a few seconds, and voila, you are automatically connecting to your Wireless Network (SSID). Now you can surf the internet. You can set this on all your computers at home that have a wireless card.
Remember to give me a good rating and vote for me. If you require further tips and tricks, feel free to contact me through the contact box. I will post up your tip.
on Apr 05, 2010 • Computers & Internet
1helpful
Hp slate 7 2800 8 gb silver at the screen for wifi asking for ssid don't what that mean haven't used it's been sitting in box given to me for a birthday present dont what to do
The SSID is the name that is broadcast by the wireless router to identify the wireless network(s). Most devices will perform a scan and provide a list of detected wifi networks. The names you see on the list are the SSIDs. It is possible for a wireless network to exist but not broadcast its SSID. In those cases you must manually enter the SSID in order for the device to scan for, locate, and attempt to connect to the wifi network.
Where to find my ssid number and password
windows 7 - open network and sharing center, click on wireless network connection, you should see your SSID, now click on wireless properties and the security tab, click on show characters to see password.
I need help to find my ssid and password for wifi
The easiest way to find your SSID is to look on your wireless router. The default SSID -- the one it came configured with from the factory -- is always located on the bottom or rear of the router. If the SSID has been changed from the default or if you don't have physical access to the wireless router, you can find the SSID from a Windows 7 computer with Wi-Fi support.
What is ssid?
Hello! SSID stands for wireless network name. This means that whenever you wanted to connect to your router, you need to know your SSID to join your network. This works very similar in connecting a new laptop to your router. Below is an example in checking the wireless network a Windows 7 Operating System is connected to. "RABBIT and maculit" are examples of SSID. I hope this helps.
We went from a windows xp to windows 7 and now our linksys won't work. it comes up error 322. help. model # WRT54GS v7.2
NOTE: For instructions on how to "Get Downloads" from Linksys Support site, click here.
Connecting to Wireless Networks Using Windows 7's WLAN Autoconfig
Follow the steps to connect to your wireless network using Windows 7's Autoconfig.
Step 1:
Click on this icon kb20600-001_en.png at the bottom-right of the screen and you will see a list of available wireless networks.
Step 2:
Select your wireless network's name or SSID then click Connect.
NOTE: If the wireless network's name or SSID is not listed, the SSID broadcast on the router is disabled. To connect to the wireless network with SSID broadcast disabled, click here.
If the computer does not connect, it is probably because the computer cannot detect any signal or cannot see any wireless network. In this case, you should change the channel of the router. For instructions, click here.
If WEP/WPA is enabled on the router:
NOTE: To learn more about WEP/WPA and other Wireless Settings, click here.
Step 3:
You will be prompted for your wireless network's security key. Click OK after entering your security key.
Step 4:
You will see the following screen and you will be soon connected to your wireless network.
Just moved to Canada and hooked my desk top up. i have internet through cable not phone line. i have internet with a cable from linksys to desk top but i have no wireless to laptops. i think i need to...
You need to configure the Linksys with the wireless settings, ie. the SSID and encryption. then you need to configure the wireless card in laptop with these router's wireless settings so it can connect with the wireless router.
Open a browser on your computer and type in the Linksys configuration URL.
http://192.168.1.1
The default login = admin
The default PW = admin
then go to the wireless section and configure the SSID and encryption. I suggest you use WPA or WPA2 these are much stronger encryption than the older WEP encrtption.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
I have the WRT54G router. I got an adapter for my USB Printer cable to Ethernet to connect it to the router. I have a wireless laptop that I would like to use to send the print jobs to the printer (a...
Connecting to a Wireless Network with SSID Broadcast Disabled when using Windows Vista & Windows 7 Article ID: 5451
Disabling SSID broadcast is another way to secure your wireless network. This will ensure that your SSID will not be detected whenever someone does a scan. When connecting to a wireless network with SSID broadcast disabled, you will have to create a profile.
Creating a Profile
NOTE: Disabling SSID broadcast is another way to secure your wireless network. This will ensure that your SSID will not be detected whenever someone does a scan. When connecting to a wireless network with SSID broadcast disabled you have to create a profile.
Step 1:
Right-click this icon kb_5451-001_en.png at the bottom right-hand corner of the screen, then select Network and Sharing Center.
NOTE: If you are using Windows 7, just click once on this icon kb_5451-003_en.png at the bottom-right of the screen then select Open Network and Sharing Center.
On the Network and Sharing Center window, click Manage wireless networks.
Step 3:
Click Add. NOTE: You have to remove your preferred network before before you proceed to click Add a new connection. If you see your network has changed from Automatic to Manual, you will face difficulties to connect your computer on the network because the SSID is not broadcasting into the available network connection. After removing your preferred network and adding it back, the network will turn to Automatic and you will be able to connect automatically into your network. Make sure to look at network properties/Connection and check "Connect when this network is in range".
Keep reading here
Just had windows 7 put on my machine, but have lost my network please could u tell me which nmber(and there is a few on back of Belkin) is my network security key please
The default wireless network name/SSID is found underneath your router. It looks something like Belkin_N1_Wireless_123456. If you cannot see the SSID in the available networks on your wireless computer, then you might have changed it to a different name.
Use a computer that has connection to the router to access the setup page. Use a browser and type 192.168.2.1 in the address bar.
Go to Wireless -> Channel and SSID. You can change the SSID to any name that you want. Then make sure that Broadcast SSID is checked. So that the computer will be able to detect the SSID.
For the network key, go to the Security tab. If WPA is set, copy the Pre-shared key. If you are using WEP, you will need to take note of the 10 digits (64bits) or 26 digits (128bits) wep key.
I hope this helps!
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
