Question about HP Media Center m7060n PC Desktop
SOURCE: power outage, now pc will not power up at all
OK FIRST A POWER SURGE PROTECTOR WILL ONLY PROTECT YOU 7 % OF THE TIME, WHICH YOU JUST REALIZED. SO YOU NEED TO BUY A BATTERY BACKUP ALSO KNOWN AS A UPS.... I CANNOT STRESS THIS ENOUGH. BRING YOUR PC TO BEST BUY AND THEY WILL TEST YOUR POWER SUPPLY, IF IT TESTS OUT OK THEN YOU BLEW SOMETHING IN YOUR MOTHERBOARD. GET A BATTERY BACKUPS/UPS!!!!!!!!!!!!!!!
Posted on Jun 12, 2008
SOURCE: hp media center power
hi friends, unpluug the power chord from the wall jack after that press and hold the power button in the front for about 15 seconds, connect the chord back in and try it. if it does the same then look at the rear side of the cpu box (where the power chord goes in and look for a small fan inside the power supply box, it has to be spinning). if not then the power supply (smps) has goen bad. now if the fan is sipnning try disconnecting all the extra periferals eg printer and stuff, still nogo then try opening the cpu box (reffer owners manual). take the RAM out and try to power up the system, if it starts beeping like beep ...beep... peeeep... then turn it off put the ram sticks back in and it should work fine...
NB:-for the owners manual check this out: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&product=470506&lc=en&jumpid=reg_R1002_USEN
Posted on Jul 22, 2008
SOURCE: hp media center pc won't turn on after electriticy
Unplug the power cord and hold the power button in until the light on the front comes on and fades out,The plug the power cord back in and start as normal.
Posted on Mar 13, 2009
SOURCE: Hi all...!!!
your hardrive has been corrupted due to the power failure.also it may have surged when power was reinstated .unless u have surge protection. if u didnt you may have burned power supply or mother board.
Posted on Jun 10, 2009
SOURCE: HP Media Center PC m1195c will not turn on,has
Remove your main power cable on the back of your PC. Let it sit idle for an hour and then try and power it up again. The memory in the BIOS should clear up and power back on.
Posted on Jul 25, 2009
