You need a seperate code for the CD player when it shows ERR... if you do not have this in your documents then you can get it for £5 from this link: Car radio codes in Uxbridge London Gumtree
SOURCE: my car battery has been
Go to the dealership with your title, registration, and photo ID, and they can use the VIN number of the car to look it up.
SOURCE: I have entered the code
Leave it SWITCHED ON...UNDISTURBED until it has automatically reset itself.
Make sure you have the correct code.
If not sure , about your code ,post the radio make+model plus all the letters+numbers on any labels, barcodes or stamped in the metal casing
SOURCE: Have Blaupunkt Cd changer attached
turn it on after turning on the motor ...and press the AS(or turn on cd player pressing this button on ) and hold to enter the code..or ..if you are already at that part the trick is that it has only 4 number buttons ..so each button is assigned to one digit in the code..
ex for the first digit ..press the number one as many times as the digit is ..
to type 2468 for example press no 1 for 2 times..the no 2 for 4 times ..and so on ..
each time you press a position it will be the number needed in that position ...
I hope I didnt made a mess with your senses....
SOURCE: The battery on our Ford
Radio code is specific for each and every car. It is specific like anti theft code. You can get it by providing your VIN# and registration details in authorized dealership. Nobody else can provide you. If anybody can provide you that , then there is no meaning of security for your car.
