Hp pavilionn dv6700 screen goes black after a while
Computer boots up ok. After a while, the screen goes black. I faintly see the background of what I was working on. I have tried shutting the computer off and on. The screen is visible for a while then goes to black.
Posted by kirk on
General Systems Consulting
    Top Expert:
  • 5,051 Answers
If you shine a flashlight on your black screen and look real hard for the icons on the desktop. If you can faintly see them that means your LCD Inverter is bad. You'll have to disassemble the LCD Screen to get to it. In the mean time you can attach another monitor (LCD Flat Screen or the Old style fat CRT) with a VGA cable to the vga port on you laptop. Once you have it connected hit the FN (Function Key) + (F1 thru F12) key that that corresponds to the external display. Hold the FN Key while you hit the Function Key that is for the external display. The key might have the words LCD/CRT on it or it might show a display symbol. That's the key you want to hit while holding down the FN key. This will cause the desktop to display on the external monitor and verify that there is no problem with your Video Card inside the laptop.
Posted on Mar 16, 2012
5 Related Answers
Anonymous
  • 124 Answers
SOURCE: HP Pavilion Dv6700 black screen after booting up
Go to the following HP website to view the problem and how to fix it:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=us&product=3636595&rule=21826
Hope you see what you are your looking for! Good Luck!
If you have any more problems let me know.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this answer!
Posted on Jan 30, 2009
Anonymous
  • 30 Answers
SOURCE: Computer won't boot Windows Vista. Screen goes black with cursor arrow.
In this case you have to do the PC restore . you can do that in dell machines by shutting down the machine and when it is coming back on just HOLD DOWN THE CTRL ket and the START HITTING f11 key in this case you will lose the data which you have the on the c drive but this issue will get resolved .
Else you can try to restart in the safe mode with networking and then go to the system restore and then select the bold dates in which you have idea you system was working fine . selct the date and then do the system restore . In this case you will not lose the data but you will lose the updates which you have done after that date .
in both the cases system will work .
Posted on Mar 25, 2009
bunnydawg
Roberta Smith
  • 5158 Answers
SOURCE: Dell Inspiron 1420 will no longer boot
you need to enter setup by tapping one of the f keys or the delete key. i'm not sure which it is for this model. when you enter the bios setup change the boot order to boot to the dvd first. hit f10 and save the change then reboot with your install disk in the drive. it should start installing.
Posted on Sep 06, 2009
Titilayo Sodipe
  • 1428 Answers
SOURCE: HP Pavilion dv6700. no screen.
Please run system restore to an earlier date.
Start system holding down f11 key till you hear a beep then follow the screen instructions.
Good luck.
Posted on Mar 22, 2010
Anonymous
  • 76 Answers
SOURCE: computer boots up and then goes to a black screen
Hi ,
Please follow these trobleshooting steps......
Turn the computer off and then disconnect any external devices connected and then when you turn the computer on or as son as you press the power button to turn the computer on start tapping the F8 key repeatedly until you get a black screen that says advance boot menu option .Then used the arrow keys on the keyboard and then hit enter,select the operating system and then when you get the log on screen select administrator .If it takes you to the desktop then you can try doing a restore by going to start ?all programs ?accessories?system tools and then system restore ? select the date when you think that you r computer was working fine and then click on next next to exit from the wizard.Should fix the issue .
If the computer does not boot up to the desktop then without wasting time on any trobleshooting steps recovery needs to be done that takes the computer back to its original factory settings.To do this instead of the f8 key tap the f11 key till you get the screen that says system recovery ,click next until you get the screen that has advance option ,click on it ?select destructive recovery ?click next the recovery will start and the computer will be formated (whatever you have added after you bought the computer would be lost ).If the recovery does not work this was then it needs to be done from the recovery disks and fot that you call call HP...
ALL THE BEST
Posted on May 18, 2010
Computer turns on, starts up ok... can hear the start up music, hard drive lightworks ok, screen goes black... after 10 mins. when this prob. started.... now it stays on (see the icons) for abt 1 min.- 30...
have you downloaded any new software? it might be the culprit if not try restoring to an earlier date when the system was working properly (like at least 4 wks ago) .. work quick since you only have 1.5 min go to start/all prog/access/systems tools/system restore...note when it shuts down it will boot up auto and you must click okay when prompt
Aug 19, 2010 | HP Pavilion dv9000z Notebook
What does it mean if my hp dv6700 won't boot up and only shows a black screen the a black screen with white lines going down it after about 30 secs.
This means that your windows operation system is failing. as soon as the computer is rebooted, please try the key F12 on your keyboard (sometimes it's F8 or these keys with the ctrl). See if you have a menu and then press load through Safe Mode. If the windows still won't load, then your windows needs a reboot. If it loads with the Safe Mode, please send me a reply through this post, so that I can further guide you.
Jun 15, 2010 | HP Pavilion DV6700Z Notebook
Good luck.
Mar 21, 2010 | HP Pavilion DV6700T Notebook
Hp pavillion DV6700 wont boot up. The light goes on so i know the power is working but that is all
You get black screen?
Yes: you need to reflow your motherboard
http://www.youtube.com/watch?v=CgTbkTK2iwk
http://www.youtube.com/watch?v=014O1Q4UctM
Jan 04, 2010 | HP Pavilion dv9000z Notebook
Screen is very faint
First, try booting into system setup. That will require hitting F1, F2, F8, f10, esc or del when bootup starts. It varies by computer and you didn't identify yours. If setup is also dim, your backlight is bad and needs to be replaced.
You could still use the laptop with an external monitor but that is not a very portable option.
Jul 28, 2009 | Computers & Internet
Screen goes black but have faint image in background
Does it boot up as bright as it used to be and then go faint or has it recently only been faint?
If it's the latter it sounds as though the lamp has gone. This can be fixed more often than not, but can be a bit expensive.
Is the laptop still under warrenty? If so go back to the manufacturer or if not you should take it into a computer shop to get a quote on fixing it.
Regards, Chris
Jun 27, 2009 | Toshiba Satellite A215-S4747 Notebook
Jan 30, 2009 | HP Pavilion dv6000z Notebook
Screen problem with HP DV 9000
I think Your computer C.P.U. power supply unit is not working properly. because these type of problem occur when Power Supply Unit is not working properly.........
So Don't afraid at all just change your c.p.u. power supply unit with new one (it is not costly at all).
Mar 19, 2008 | Computers & Internet
Computers & Internet Logo
104 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
