These problems began to occur after I had an alignment done 3 days ago. Anyway, i got a second alignment/opinion 2 days ago. Both places say that the vehicle alignment is in manufacturer's specs. If it isn't the alignment of the vehicle, what else could be the problem? Please note that I couldn't understand the tech but he pointed to the steering gear box and he said the word "loose."
If the tech knew your steering box was loose i dont understand why he didnt attempt to adjust it for you.some vehicles are adjustable and some need to have the steering gear box replaced when loose. the vehicle should re center itself upon letting go of the wheel. there is an issue that has gone undiagnosed. you could have tire issues (unevenly worn due to driving on them with bad alignment for long period of time) low tire pressure could cause this too. to test your alignment find a good flat round (with no crown) let go of the wheel while driving (keep your hand there so you can quickly re grab the wheel) and see if the car pulls one way or another. if the road has a crown to it the car may drift some but this is normal in a parking lot or flat road it should go in a perfectly straight line. also over tightening the steering gear box could caus this issue. my recommendation to you would to be to research a more reputable/highly recommended shop to take another look at it for you. it sounds to me that both shops you went to may do alignments but might not be trained supension/steering techs. in other words theres something going on they dont know about
