SOURCE: GSA-H10A CD/DVD not recognizes as a burner
Hello my friend, how are you? regarding on your problem kindly try nero burner software. Here's the link where you can download nero for free. Download Nero Burner.
Kindly install it in your system and then try it... I am using this burner for almost 10 years... Hope it will help your problem solved.
If you need more assistance just reply to this post.
Thanks
SOURCE: How do you set a LG GSA-H10A DVD Drive as a Slave?
on the drive there will be printed or stamped:
MA, SL, CS (maybe in a different order.) Often there is a printed label, and often the re are tiny letters stamped either above or below the jumper pins.
You need to place a jumper in the vertical position over 1 set of pins corresponding to the map above.
ie if you want the drive to be a Master, jumper the vertical set marked (or indicated) as MA.
If you want it to be Slave, jumper the SL set.
If you want the drive to be set depending on where on the IDE ribbon cable is conected, connect the pins marked as CS.
BIOS will then allocate the drive as either a master or slave.
Using Internet Explorer but not Firefox, get the manual here:
http://www.lg.com/uk/support/product/support-product-profile.jsp?customerModelCode=GSA-H10A&initialTab=warranty&targetPage=support-product-profile#
Note the manual is a dejaVu document which will ask to load a viewer plug-in into Internet Explorer.
Actually, inside that document, there is a drawing indicating that reading from left to right (ie from next to audio connector), the pins are: CS,SL, MA. So for example upper and lower pins at the extreme left are Cable Select, so you would jumper those 2 pins.
Cheers,
Steve
SOURCE: Where can I get a Windows 7 driver for free for my
Welcome to Fixya
Windows 7 should detect this device automatically. Did you replaced your DVD Rom drive. DVD rom drives are plug and pluy devices. Windows 7 will supply this device with default drivers once you installed it. If you clicked on Computer did you see the icon for your cd rom drive?
Your feedback will be highly appreciated.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: I NEED A WINDOWS 7 DRIVER FOR MY LG
Use these drivers. They work on XP and should, therefore, work on Win 7
http://www.lg.com/uk/support/product/support-product-profile.jsp?customerModelCode=GSA-2166D&initialTab=documents&targetPage=support-product-profile
