Question about Samsung PCL541R 54" Rear Projection Television
Samsung PCL541R vertical position is too low - partial
The bottom rolling banner, typically seen on news and sports programming, is missing it's lower half. Can an old electronics tech easily find the size and position adjustments? As I've never opened a rear projection before, do they exist or are they mechanical (mirror adjustments)?
Posted by James on
  • James Mar 20, 2012
    How are the display vertical size and position adjusted on my PCL541R?
  • James Jun 13, 2012
    I downloaded the service manual and was able to resize the display, although it was through trial and error as much was not explained. I suggest users record any settings prior to manipulation.
SD Tech
    Top Expert:
  • Samsung Master
  • 14,553 Answers
The adjustments are if present on this model in a hidden tech menu that is called up----with set on most of these sets with the original remote call the menu up with display 182 or 183---different buttons once in select items and cursors adjust them You might want to GOOGLE to see if you can find a service manual to guide you.
If you make it into tech menu use real care as easy to select and adjust incorrectly---most items in the menu will have a number showing the current setting to which it is a good idea to write down.
There will be a save or "Data" button also
I am going by memory here but have been in that menu before more than a few times.
Posted on Mar 21, 2012
4 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: SAMSUNG HCL4715W
the HCL473W, HCP4752 are basically the same set same features. The HCL models like the HCP are rear projection. Unfortunately Samsung no longer manufactures the rear projection CRT models they are only available in the DLP rear projection with the closest comparable model currently available for a new replacement would be the HL50A65 which is a 50 Inch 1080P suggested retail 1299.00 If I can help you further please let me know. Also new replacement chassis are available for the HCL4715W.
Posted on Jul 02, 2008
ABRsvcs
  • 4234 Answers
SOURCE: Picture shadow on rear projection Sony big screen TV
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Dan
Posted on Sep 25, 2008
Anonymous
SOURCE: Sound quit on Samsung rear projection TV
We solved the problem by purchasing a surround sound system and hooked it up to the Cable box thus bypassing the TV speakers. It was a cheaper fix than having a TV repair service guy come out and we have even better sound! Thanks anyway!
Posted on Jan 14, 2010
Chi Chu
  • 8457 Answers
SOURCE: RED CONVERGENCE SCREEN PATTERN BOWING AND CAN'T ADJUST
Try website Tv repair World.com to buy a whole convergence board for the replacement.The Akai/Samsung tvs used the same convergence board.
Posted on Apr 21, 2010
Partial picture for samsung un40j520. TV was dropped and now partial vertical picture. Picture covers about 7/8's of screen and missing a vertical strip on left side of screen
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.....
Nov 21, 2016 | Samsung Televison & Video
Samsung plasma has a black vertical line through almost the middle of the screen. It's partially opaque. Kid spilled water all over the screen the day before, but the line didn't show up until today.
Hello. I'm afraid that water has caused damage to the panel. There are boards across the bottom with ribbon cables attached to the panel, and the IC that feeds that section has failed. It is not repairable except by replacing the panel, which will cost as much as a new TV. Sorry about the bad news.
Aug 09, 2016 | Samsung Televison & Video
My stealth g5 will not turn on it will load but will stay on the android banner and will not turn on fully. What is wrong with my tablet?
About 587,000 results (0.78 seconds) Search Results
    How to fix Samsung Galaxy S5 that won't turn on ...
    thedroidguy.com/.../how-to-fix-samsung-galaxy-s5-that-wont-turn-on-tr...
    Jun 4, 2015 - Without power, your Samsung Galaxy S5 will become an expensive ... S5 owners seeking assistance because their device won't turn on or won't ... But the real focus here is how to bring the phone back to life. ... in this mode considering theAndroid GUI will not be loaded during boot up. ... Load Comments ...Missing: banner
    Samsung Galaxy S5 Won't Turn On or Boot Up After Lollipop ...
    thedroidguy.com/.../samsung-galaxy-s5-wont-turn-on-or-boot-up-after-l...
    May 29, 2015 - "Hi droid guy, my Galaxy S5 won't turn on after I installed the lollipop update. ... after Android 5 Lollipop update was rolled for the Samsung Galaxy S5. ...More often, the screen stays black but the backlights are clearly lit, ... But if you know how to fix this problem, please guide me so I can .... Load Comments ...Missing: g5 ‎banner
    Samsung Galaxy S5 Problems After Android 5.0 Lollipop ...
Feb 03, 2016 | Tablets & eReaders
The scrolling banners on the top and bottom of my zenith monitor are cut off. according to my manual, it is 1 of 6 models: SR2573, SR2783, SR2739, SR2773, SR3238, SR3273.
Either an adjustment of the vertical height or Lin or a circuit problem in the vertical circuit.
Some sets have physical controls inside the set on the board or in a hidden menu via the remote.
Nov 07, 2012 | Zenith Televison & Video
Sony bravis is cutting off the top of heads . Also no banners on the bottom of screen on sports stations.
either or both Synconous control and vertical stabiliser chip is fritzed had the same problem on my set last year and that is what is written on Invoice ( Vert stabiliser and DSync chip replaced..$250)
Needs professional Intervention, NOT a DIY
Please rate our help++++Thanksd for using FIXYA
Oct 09, 2009 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Printer won't print 17''x76'' long Banner on Canvas
What is the page setup in the Indesign Program?  Sounds like is is trying to print to the standard paper size of 8.5 X 11.  See if the program allows you to change the page set up to 12"X66" to match the banner.
Hope this helps...
~enov8
Feb 16, 2009 | Apple Computers & Internet
Picture adjustment on zenith SM3247MK8
Probablemente tengas problemas en el circuito vertical o los capacitores adyacentes hay que checarlos.
Mar 20, 2008 | Televison & Video
Display adjustment
hi there, bottom adjustmet means a vertical section control adjustment. a vertical size, vertical position control adjustment. do some check up on users control manual adjustment. ty
Dec 29, 2007 | Philips Magnavox 24MC4306 24" TV/VCR/DVD
Samsung PCL541R 54" Rear Projection Television Logo
91 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
