27. (00011011) Fabric Softener Valve Fault
The Motor Control Module has measured a voltage from the valve diagnostic circuit that
indicates the fabric softener valve (with Yellow Clip) is faulty. The most likely cause is that
the valve harness has not been connected correctly or the valve is open circuit. See fault
code 49 for service procedure.
49. (00110001) Cold Valve or Cold Valve & Hot Valve Faulty
indicates the cold valve or both the cold and hot valve is faulty. The most likely cause is
that the valve harness has not been connected correctly or the valve(s) is open circuit.
Primary Source: Wiring.
Action: Check the valve harnesses are correctly fastened to the valves and
the motor control module or the pins are not bent backwards.
Secondary Source: Water Valves.
Action: Measure the resistance of the cold and hot valve coils.
Tertiary Source: Motor Control module.
Action: Replace the Motor Control module.
I am getting a faulty 27 on my machine. Can I fix this myself
