Question about Bissell Vacuums
USER MANUAL FOR BEX BISSELL PRO HEAT PLUS 2X + MODEL 9500-E
BEX BISSELL USER MANUAL FOR PRO HEAT 2X - MODEL NO. 9500-E
Posted by christi23258 on
Think Crucial
    Master:
  • Bissell Master
  • 894 Answers
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Bissell model by clicking the link below.
BISSELL 9500 User Manual
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Posted on Oct 15, 2017
5 Related Answers
Anonymous
SOURCE: My Bissell Pro-Heat 2x 12
my bissell 9200 won't release water or solution when the trigger is pulled.
Posted on Nov 20, 2008
reddevil6
Lauren Junge
  • 1673 Answers
SOURCE: Bex Bissell Pro Heat 7920-E
Remove the cap for the flow indicator, then there 6 screws to remove to take off the top, before removing the top, turn the smart mix valve to about the half way point so the piston won't fall off. When you are ready to re-install the top cover, just before pushing it all of the way down, turn the smart mix valve to the water only setting, then push it into place, re-install the screws and the flow indicator parts.
Posted on May 28, 2008
Anonymous
SOURCE: Bissell Pro Heat 2x steam cleaner, problems!
I took the side plastic protectors off because my brushes stopped working. I found one belt almost broken (held together by the fiber to the interior) and when I moved the brush rollers, I found mucho dog hair on the ends. Your rollers might be removed and see if you have the same problem. IT just takes two screws on each end to do this, so if your belts are good, take a look at each end where the metal post goes into it. I have two dogs and their hair is just everywhere!
Posted on Jun 25, 2008
Anonymous
  • 120 Answers
SOURCE: My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
Posted on Jul 06, 2009
Anonymous
SOURCE: PRO HEAT 2X BEX BISSELL
Either the heater unit is blocked, clean it out, or I had the same problem, take the water tank out, look on the bottom, is there a red seal on the tank? If not, its either lost (can get new one here http://www.4bissell.co.uk/cgi-bin/product.pl?PID=947370&query=7920%2de) or more likely its stuck in the bottom, if it is get a screwdriver and prise it out of the base and put it on the tank. All should be well. Regards Paul
Posted on Jan 10, 2010
Brush Bar not turning on a bissell pro heat 2x
Here is the Instruction or User Manual for the 9500 series machines
will give instructions how to check and change drive delts
Dec 12, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
I need a repair manual for a Bissell Proheat Cleanshot 2x model 9500
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Sep 08, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Pro heat Carpet cleaner
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
Jul 07, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Looking for instruction manual for Bissell Pro 2 carpet shampoo machine
Oct 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Want to use Bissell Pro Heat 2X Clean Shot. Have
You can download a user manual from the Bissell website
Sep 15, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Carpets soaking wet
turn dial in front on the water tank to floor not tools and thats should do it...go to bissell.com to read and print manual so you can double check everything
Feb 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Pro Heat is not releasing water to do the job! Works only briefly.
You can find a cop of the instruction manual at http://www.bissell.com/Product_Search.aspx?Criteria=9500+pro-heat
Click on User Guide and a PDF will download.
Aug 17, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
460 people viewed this question
Top Bissell Vacuums Experts
Marvin
Marvin
Mike
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
