Question about Nikon D3100 Digital Camera
Some time internal flash does not work in my nikon D3100 camera
I generally use program mode when it stopped flashing i used manual mode but it did not work then I turned to Auto mode and it flashed... I don't understand what is the actual problem..
    Scholar:
  • 86 Answers
When in program and manual mode, you will have to set it to flash. Make sure the circle around the electric bolt on the screen does not have a line through it, and it should work. There is usually a button with the symbol on it somewhere around the lcd(I'm not very familiar with your model or I'd tell you where) or it may be in the on screen menus if it's not a button around the screen.
Posted on Mar 15, 2012
6ya staff
SOURCE:
I need a operating manual for Sunpak Auto Thyristor G4500DX Flash gun only
I found this for a Sunpak flash which is similar to the G4500dx:
Reading from the "auto555/G4500DX" Manual, you need to:
1. Slide the Film Selector to desired ISO - (that is the same as your camera ISO used - so, make sure you turn Off the Auto ISO feature if your camera has one).
2. Slide the Mode Selector to "A" (Auto position). This will be Auto Thyristor mode on the flash.
3. Slide the Auto F/stop Selecct Know to desired lens openning - ( so use your camera in Aperture priority mode, more in Manual to prevent changes in the camera aperture value during shooting)
Shoot, and be happy with well exposed pictures by the Auto Thyristor features of the Sunpak 555 flash.
The Sunpak 555 works great with Nikon D50, D70 cameras, as you can synchrinize flash practically at all shutter speeds. Excellent for sunny days to get narrow DOF, yet get any ambient light level contribution as desired.
For other cameras, make sure (watch out for) that Aperture Priority mode does not use shutter faster than the camera max X-sync speed - so Manual camera mode could be a better choice for a novice photographer.
In the manual there is also a list of accessories for various brand cameras, How to use Power Ratio in Manual mode, some advice on using wide lenses, how to care of your 555, and Specification section.
Minimal flash duration is 1/450 at full power, so you can safely use Auto Aperture up to 1/500 sec. Flash duration decreases with lower power setting, or lower auto mode need for poser, and the shortest flash duration is 1/17000th sec.
Jan 29, 2016 | Sunpak Cameras
Hello, I have a sony DSC-T70 and I cant change the flash options. i should be able to select the flash icon and choose my flash setting, but the only setting is no flash. I really want my flash to work...
hello
Have you consulted the manual in this?
http://129.33.22.12/release/DSCT70.pdf
pages 15 to 18
But in any case I beleave you first need to set your camera into the PROGRAM AUTO mode
13df56d.jpg After you have set your camera to program auto you should be able to change the flash settings as below
Let me know if you need more assistance.
May 01, 2008 | Cameras
Can i use my vivitar 4600 with my nikon d300s?
Yes. You can use the flash in auto or manual mode by setting the camera to manual shutter speed within the x-sync range and then selecting the aperture prescribed by the flash guide number or the displayed automatic f-stop on the flash. The flash can provide auto exposure with the camera in manual mode, but you need to be aware of the amount of ambient light which will not cause any exposure corrections by the camera in this mode. Another alternative is to select Aperture preferred automatic on the camera and the f-stop shown for the auto flash settings. This will allow the camera to vary the shutter speed but may cause long exposures if the camera is not sensitive to real-time flash readings.
May 05, 2014 | Vivitar Cameras
Setting the clock on a brinks timer 44-1011
I finally found the instructions for the Brinks timer 44-1011 and they work.
    • BRINKS DIGITAL TIMER 44-1011 INSTRUCTIONS
    • CURRENT TIME SETTING
    • 1*Press and hold the OK button for 4 seconds. Hour Display flashes.
    • 2*Press +/MANUAL or - to select the hour. Press OK to confirm.
    • 3*Minute display will now flash. Press +/MANUAL or - to select the minute. Press OK to confirm.
    • 4*Press MENU to exit the time setting mode. Now the timer is in clock mode.
    • PROGRAM SETTING NOTE: This timer can be set up for up to 2 different programs. We will use PROG 1 for this example, however these steps can be repeated for any of the 2 programs. To cycle through the individual programs use the +/MANUAL or - after pressing MENU in step one until the desired PROG "#" is flashing. To clear a program setting hit the RECALL button when you have the program selected.
    • 1*Press MENU button, PROG 1 "ON" will flash, press OK.
    • 2*Hour will flash. Cycle with +/MANUAL or - to desired hour, press OK.
    • 3*Minutes will flash. Cycle through minutes +/MANUAL or - to desired minute, press OK.
    • 4*Program will be flashing again. Press +/MANUAL to get to PROG 1 "OFF" blinking, press OK.
    • 5*Repeat steps 2-4 to complete PROG 1 setting.
    • 6*When done setting programs press the MENU button to return to clock mode.
    • 7*Press +/MANUAL to have LCD showing either "AUTO ON" or "AUTO OFF" for the timer to execute the programmed settings.
    • DAYLIGHT SAVING TIME SETTING (DLST)
    • 1*In clock mode, press RECALL to turn on or off the Daylight Saving Time.
    • 2*Turn on DLST, the below of LCD shows +1H. Time is adjusted by adding one hour.
    • 3*Turn off DLST, +1H will disappear and LCD shows the real time. MANUAL OVERRIDE AND ALWAYS ON/OFF When in clock mode the +/MANUAL sign cycles through
    • 4 settings that serve as manual override. **ON - Indicates that the timer is in the ON mode, and will always be on regardless of the programmed setting. **AUTO ON - At this selection, the timer will come on regardless of the programmed setting, but it will follow the next programmed command. **OFF - Indicates that the timer is always off (i.e. the wall socket is turned off) **AUTO OFF - Indicates that the timer is in the OFF mode until the next programmed step that turns it ON.
    • NOTE: For normal timer function, the selection must be either "AUTO ON" or "AUTO OFF". RESET At any mode, press RESET for 5 seconds. All settings will be cleared, return to clock mode, 12:00 MO, AM, AUTO OFF will be shown on LCD
I hope this is helpful. It was a bear to find.
Dec 24, 2012 | Hardware & Accessories
How do I disable the pop-up flash on Nikon D5000? Thanks
As long as jog dial is set to M or manual, the flash will not pop up automatically. Be reminded though because you have to set everything manually. If you want the auto settings without the flash, set the jog dial to the icon that looks like a lightning with stop/ no sign
Mar 02, 2011 | Nikon D5000 Body Only Digital Camera
My camera doesnt' work indoors. i try to take a picture and it doesnt' take when I'm in AUTO mode. However, when I'm in LANDSCAPE mode the pic will take. it seems like the flash isn't active in AUTO...
You must have a software glitch because the flash is supposed to be in the auto mode when the selector is in auto, unless you manually turn the flash off and the flash should go back to auto every time the camera is turned off and back on. Here's a work around. Turn the dial to indoor and use the flash button on the ring to set the flash to auto. In the indoor setting you can set the flash to on, off, or auto.
Dec 19, 2010 | Canon PowerShot A720 IS Digital Camera
My flash isnt working on my A835 camera and i have only had it for 6 months
Check the flash mode that your camera is set to. The flash modes are: Auto, Red-Eye Reduction, Forced Flash, No Flash, Slow Synchro, and Red-Eye plus Slow Synchro. You might have the flash mode set such that your camera detects that the lighting doesn't require the flash mode selected. You can try manually overriding the flash mode by pressing left on the circle function button next to the LCD view screen. If you are still unable to manually turn the flash on, try changing the shooting mode with the mode select dial on top of the camera, then if necessary repeat the flash override step mentioned above. Repeat until successful. There is also the possibility that the flash is malfunctioning, but that is less likely than a setting issue. Let me know how you make out.
Jan 02, 2010 | General Electric A835 Digital Camera
G9 flash
My flash doesnt work either. Holding the flash button down doesnt do anything either (in program mode)
Apr 08, 2008 | Canon PowerShot G9 Digital Camera
Built-in flash and an external flash simultaneously
Yes, please see the following table: Optional Flash Flash Control Mode Capacity FL-50 TTL Auto (Super FP flash)/ TTL Auto/ Auto/ Manual/ Manual (Super FP flash) The FL-50 flash can be connected with the E-300 camera through flash power grip: FP-1 and flash cable: FL-CB05. FL-40 Auto/ Manual The external flash cannot be used with the built-in flash. * Only Auto and Manual mode can be set in the concurrent use of FL-40 and the built-in flash. (For their specification design, E-300 and FL-40 can not communicate in TTL Auto and R-TTL Auto modes.) FL-36 TTL Auto (Super FP flash)/ TTL Auto/ Auto/ Manual/ Manual (Super FP flash) The external flash can be used with the built-in flash.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Nikon D3100 Digital Camera Logo
223 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
