Question about Water Heaters
How to change diaphram
SOURCE: Rheem 300170 HWS service manual
1) Rheem does not post service manuals.
Call Rheem and ask why, since the other big manufacturers, AO Smith and Bradford White do post service manuals.
2) You need new propane gas control valve, and matching combustion parts to fit existing tank.
http://waterheatertimer.org/pdf/Rheem-Water-Heater-parts-catalog.pdf
http://waterheatertimer.org/images/IMG_1826-LP-burner-450.jpg
3) Rheem does not recommend changing gas type, especially from natural gas to LPG.
LPG is higher pressure, and burns much hotter and requires cast iron burner, unlike the lighter-weight metal used for Natural gas burner.
The manifold tube and thermocouple must match the gas control valve, and gas-type and have correct thread for propane.
The combustion chamber and heat transfer surface can also be heavier metal for propane heaters.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Feb 08, 2013
Ask a neighbour or 2 in your building who no doubt have the same system installed in their apartment.
Posted on Jan 06, 2016
Jan 06, 2016 | Water Water Heaters
Feb 08, 2013 | Water Heaters
Aug 16, 2011 | Rheem RTG53DVP Direct Vent Liquid Propane...
Jul 31, 2011 | Reliance Natural Gas Water Heater Control
Mar 05, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Jul 16, 2009 | Water Heaters
Feb 21, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
Dec 13, 2008 | Bosch AquaStar Indoor Natural Gas Tankless...
1,574 people viewed this question
