Question about Visonik Car Audio & Video
I have a used amp V117SX (Visonik)
I got it used. I have know idea what i am doing. It has a female conntion on the back 6 Wire plug. How would i go about hooking it up?
Posted by garry_medlin on
3 Related Answers
Anonymous
  • 5 Answers
SOURCE: Visonik V117SX Car Audio Amplifier
The RCA cables are for leads from your deck to your amp. Assuming you have an aftermarket deck, pull it out of the dash and look at the back. There should be a red out put and a white output for your cables to plug into. They're sometimes labeled left and right to help you make sure you hook up the amp right. If not, just be sure to match them up between the deck and the amp. If you have the stock deck in there, it's unlikely that you'll have RCA outputs, as most stock decks I've seen do not. As for the protection light being on, your amp is most likely shorting to ground somewhere. Be sure you don't have it screwed right to any metal parts of the car, as this can cause problems. Most amps have a section in the manual warning against this and the problems it can cause. Some amp manufacturers don't say anything about that or say that it will be safe, but, as a rule, I always just play it safe and mount it either to my sub box or on a piece of plywood or something that is secured in the car. Also, make sure that the in-line fuse on your power lead isn't blown, and most amps have one or more fuses on the side of them, so check those, too. If none of these things are wrong, then it might be an internal problem and I can't really help you with technical stuff. Hope this helps. Please leave feedback, too.
Posted on Oct 10, 2007
kenw392
kenw392
  • 2226 Answers
SOURCE: Visonik v117sx came with no input plug. Needing
if you have rca's coming from the back of your head unit, you do not need the high level input harness.
Posted on May 08, 2009
Anonymous
  • 180 Answers
SOURCE: Nothing will come on
have you wired it back in correctly? and have you connected the auto ariel lead back to the remote connection on your amp?
Posted on Mar 18, 2010
Got a used V117SX without the 6 wire plug. WHAT CAN I DO?
You can only use it for subs....That wiring harness is for smaller speakers. If you have subs and you have an aftermarket radio you will need to run rcas, a ground power wire and a remote.
Mar 14, 2012 | Visonik V117SX Car Audio Amplifier
Mar 17, 2010 | Visonik V117SX Car Audio Amplifier
WHY DOES MY AMP CONTINUE TO BLOW ITS FUSE ..I HAVE A 4GA AMP KIT ON IT ......IS THAT TO BIG ..I DONT EVEN HAVE ANY SUBS HOOKED TO IT ..VISONIK V107SX
go with an 8GA wire and see what that does for you because the battery is sending power to an amp but the amp cannot transfer all of that power anywhere without speakers being ran to it if you think 8GA is to small then try running a fuse in with your 4GA
Jun 23, 2009 | Visonik V117SX Car Audio Amplifier
Need to know what connections for 6 pin input port
honestly anything made by visonik is **** and i wouldent try wiring it like that it could have bad consequences do rca or call visonik and order a replacement
Apr 26, 2009 | Visonik V117SX Car Audio Amplifier
Do you know how to hook thise amp up to a wall socket?
sure but for what aplication your better off getting a 12v battery connecting it to that ten connect a battery charger to the battery
Apr 13, 2009 | Visonik V117SX Car Audio Amplifier
Amp problems
The head unit probably has 2 control wires. One has 12v when the signal source is the tuner. When you switch to the other sources, the antenna is not needed so the output to that wire is switched off (so the power antenna will go down).
Look for a wire marked amp control or something similar. It will have 12v output any time the head unit is on. Use that one to control your amplifiers.
Apr 04, 2008 | Visonik V117SX Car Audio Amplifier
Oct 10, 2007 | Visonik V117SX Car Audio Amplifier
Car Audio & Video Logo
Top Visonik Car Audio & Video Experts
xxxxxx xxx
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
