Olympus Camedia C-765 Digital Camera Logo
Question about Olympus Camedia C-765 Digital Camera
C-765 when "all reset" is set to 'off' when I change the battery, the camera setting reset. Can the internal battery be replaced?
4 Related Answers
Anonymous
  • 75 Answers
SOURCE: Camera looses date & time setting
There is a cmos battery (or a memory battery) on the main circuit that like any battery wears out eventually. If you are familiar with repairing electronic circuits you can get the part from Olympus. There is no part number just "memory battery for C-740" will suffice. Your other two choices are to take the camera to a shop where they can do the kob for you. Don't let them sell you a complete new board, you don't need one. Not for this problem anyway. Or you can ignore the problem and reset the camera (or not)each time you change batteries.
Posted on Mar 31, 2007
Anonymous
SOURCE: replacement of the internal battery
Both of these cameras have a small MnO2Li coin battery type CR2025.
It five minutes work to replace and you don't need to take the whole camera apart. The battery is located in a rubber holder located on the 1400 underneath the hand grip. You need a stout tooth pick or unbent paper clip to pull it out.
Alterntively take your cemera to a real photo place where they should do the replacement for the cost of the new battery.
Posted on Dec 12, 2007
Anonymous
SOURCE: Lose custom camera settings.
The problem is that the capacitor is not working any more. At this site you can find all the details.
http://www.pbase.com/ociepka/750
Posted on Apr 04, 2008
Anonymous
SOURCE: Custom settings disappear
This was already answered! See prior questions... indicates to go here for how to
Posted on Jul 13, 2008
1helpful
Why does changing the battery disable all the menu alterations and user settings I save on the p6000. Is there a way around this problem
Their is a small internal battery that holds the time inside the camera, Sounds like the internal battery is dead
tip
Nikon Coolpix keep resetting Time and Date and menu settings.
Hi.
I am listing this tip for the Nikon Coolpix 995, but the tip is valid for all Nikon Coolpix models.
The Nikon cool pix settings are saved into an internal memory.
The internal memory is maintained by an internal rechargeable battery, that is recharged from the main Li-Ion battery.
If you leave your Nikon overnight with no main battery, or if the Li-Ion batteries have drained, then the internal battery will also drain , resetting the clock and other settings, saved on the internal memory. The camera may even drain in about 6 hours depending on the camera, normally it takes at least 12 hrs to drain the clock battery.
If the internal battery is resetting immediately, after you set the clock, or just after few minutes, then the clock battery must be replaced.
The camera must be disassembled completely to replace the battery located on one of the two main internal boards.
Nikon says that the clock battery loosing charge is normal. I quote what they say on the publication titled " The Nikon Guide to digital photography with Coolpix"
"Backup battery of the clock
The clock-calendar is powered by a separate rechargeable battery, which is charged as necessary when the main battery is installed. If the camera has been stored with the main battery removed for a long period of time, the clock may need to be reset. Once the main battery has been reinserted, the clock battery will recharge in several hours, during which time the main battery should be left in the camera."
Original file: Download here
If the clock does not work at all, and is resetting immediately, even though the Li-Ion batteries are fully charged, then the best thing to do is calling Nikon, at the number listed on the owners manual, telling them that you did not do any improper use of the camera, and trying to get the fault repaired as factory defect. That is not always possible, and the decision depends on Nikon customer service.
See also: Nikon | Contacts
Ginko.
Reset to factory setting
Remove the battery for 20 mins. Then replace the battery and go to the camera's Menu setting and set the date & time.
2answers
I have had my S9600 for 4 years, for most of that time, when i changed the batteries, all my settings remained the same. Now, when i change the batteries, every setting has returned to factory standard...
No internal battery. After the batteries are in the camera for 2 hours, there is enough charge in the camera to hold on to settings for 6 hours. If you take longer than that to install fresh batteries, the settings are lost. Here's what the manual says:
DATE/TIME
DATE/TIME
OKOK:At the time of purchase and after leaving the camera for a
long period with the batteries removed, settings such as the
date and time are cleared. Once the AC power adapter has
been connected or the batteries have been installed for 2
hours or more, the camera settings will be retained for
roughly 6 hours even if both sources of power are removed.
3helpful
Olympus C-765 - won't take photos anymore. Memory card is fine and camera has worked perfectly for the past two years. Does anybody have a solution? The camera seems to function as normal, but when I press...
Reset the menus to default or factory settings.
Then test the camera again.
Make sure that the battery is fully charged or new.
You might consider to buy a new battery (Ebay is a good place) for this camera. Then test.
Problems like this can show up when the battery is weak or not fully charged.
You may try to remove the battery for 24 hours and then after try it again.
Is there an internal battery for the time and the date?
Manual says: "After installing the batteries, the set-time/date message may appear on the monitor. The clock and calendar are set in section 3 of the setup menu (p. 18)."
In fact if you replace batteries really fast (in a minute or two) and time is reset the internal battery is probably exhausted/broken. You have to decide if it is worth of repairing.
My Z1 has 6 years and the clock does't forget time. Maybe next time i'll be surprised...
12helpful
2answers
Fuji FinePix S9000 battery change clears date/time.
Hi
I started having a similar problem with my Fuji FinePix F10 after about 3 1/2 years of problem-free use. Another poster had some really helpful advice which I thought I'd pass on. It seems there is an internal battery or capacitor which basically fails after a while, meaning date/time settings etc are lost when the battery is removed. (Some people claim this is a motherboard/chip problem instead - seems to be contentious!) So the camera is faulty, but the problem can be worked around.
The advice I found, which worked for my camera, was this:
- Turn off camera and leave off for approx 15 seconds before opening battery door.
- Change battery quickly (within a few seconds).
- Close battery door and leave camera off for approx 15 secs before turning back on.
This retained all settings when I tested it multiple times. I imagine it might not work if changing over a totally dead battery though.
Hope it helps!
F
Changing the battery resets my date. is there another battery
your camera doesn't have internal battery so everytime you change the battery it will ask you to set the date...
1helpful
2answers
2answers
When battery is changed date and image size need resetting
Internal battery or capacitor may be bad and not holding charge to keep settings.
Top Olympus Cameras Experts
Steven Wander
Steven Wander
David Shaub
Steve
Are you an Olympus Camera Expert? Answer questions, earn points and help others
