Question about Galaxy Radios DX- 88HL Base CB Radio
Mirage 88.. RX okay TX distorted
RX okay TX distorted.. Astatic Road Devil mike.. worked great for years.. also noticed one time that mike was hot (temperature) battery shorted inside? replaced battery.. worked fine now doesn't work.. TX distorted
Mike Charette
    Genius:
  • Galaxy Radios Master
  • 1,847 Answers
Try the original mic . If its still distorted then it,s a radio problem.
Posted on Jan 12, 2015
3 Related Answers
lars ahlsen
  • 47 Answers
SOURCE: very old astatic 525 mike wiring
Hello..maybe not a solution..but a hint..measure red-black for 0 ohms while pushing "ptt button" i think it's ptt...bare and transparent is mike...but you can look at original mike and make the same measurement for finding out what is ptt..the two others is mike ...good luck...Ron
Posted on Mar 13, 2008
Ironfist109
Iron
  • 3018 Answers
SOURCE: have galaxy 88 radio started
It sounds like your crystal has gone bad. More than likely it is the 10.25 crystal. Unfortunately if you have no Oscilloscope then you need to take it to a radio tech as you have to inject a frequency into the triple band to get the radio to Oscillate again, once the crystal is replaced.
Regards, Tony
Posted on Apr 27, 2011
Melanie Rogers
  • 219 Answers
SOURCE: The problem had been coming on for about a month.
This could be a couple of different things,the easiest is your freq.somehow got off the worst case is the PLL went bad,either way your going to have to take it to a shop.Sorry
Posted on Jul 10, 2011
Wiring rd104e to a 142gtk cobra
Mic Wiring
Stock
1- Audio
2- Shield
3- Receive
4- Sw Com
5- Transmit
Oct 06, 2013 | Astatic Road Devil RD104E CB Radio
I need the wiring code rd104e mic to a rci 2950 dx 6 pin
1. Ground Shield
2. Audio Yellow
3. Transmit Red
4. Receive Black
5. CH. Up White
6. CH. Down Blue
Oct 15, 2012 | Astatic Road Devil RD104E CB Radio
Looking for the best micaphone for cobra 148gtl
Turner+2 Ham CB Radio Microphone Transistorized SSB Base Station Shark Fin
turner microphone ' eBay
Jul 29, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
I want to wire an Astatic d104m6 to a HR 2510 radio
To wire that mic to that radio -
  1. White - TX
  2. Shield - Braid
  3. Black - RX
  4. Blue - Common/Switch
  5. Red - TX
Regards, Tony
Apr 24, 2011 | Radio Communications
My new Astatic Road Devil will not transmit audio on my Cobra 2000, it came with a 4pin plug and I put on a 5pin 1 white(audio) 2 shield 3 black(recieve) 4 blue(common) 5 red (transmit) yellow(n/a)
recheck that you have the wiring correct. you will need the wiring of the cobra 2000/148gtl/grantxl... can't remember the pin outs. what you have posted is not the correct one??? i think.
Dec 26, 2010 | Astatic Road Devil RD104E CB Radio
Astatic road devil mic, which wires connect to the 1,2,3,4 pins
the shield with(bare wire) and blue wire both go on the pin one. followed by 2white, 3red, 4black.
Nov 01, 2009 | Radio Communications
Cannot send or receive a fax. I can hear a click when I hit tone and that?s it. It worked before but after I fixed error 6502 nothing.
(2) Service error codes
on.
- Logic board
#001 TX Document jam
#003 TX / RX Document is too long, or page time-over
#005 TX / RX Initial identification (T0 / T1) time-over
#009 RX Recording paper jam, or no recording paper
#012 TX No recording paper at the receiving machine
#017 TX Redial time-over, but no DT detected
#018 TX Auto dialing transmission error, or redial time-over
#022 TX Call failed (no dial registration)
#037 RX Memory overflow at reception of an image
#085 TX No color fax function supported in the receiving machine
#099 TX / RX Transmission terminated mid-way by pressing the Stop/Reset button
#995 TX / RX During TX (sending): Memory transmission reservation cancelled
During RX (receiving): Image data received in the memory cleared
Error code TX / RX Meaning
##100 TX Re-transmission of the procedure signal has been attempted the specified number of times, but failed.
##101 TX / RX Sender's modem speed does not match the receiving machine.
##102 TX Fallback is not available.
##103 RX EOL has not been detected for 5 seconds (or 15 seconds in CBT).
##104 TX RTN or PIN has been received.
##106 RX The procedure signal has been expected for 6 seconds, but not received.
##107 RX Fallback is not available at the sending machine.
##109 TX After DCS transmission, a signal other than DIS, DTC, FTT, CFR, or CRP has been received, and re-transmission of the
procedure signal has been attempted the specified number of times but failed.
##111 TX / RX Memory error
##114 RX RTN has been received.
##200 RX A carrier has not been detected for 5 seconds during image reception.
##201 TX / RX DCN has been received in a method other than the binary procedure.
##204 TX DTC has been received even when there is no sending data.
##220 TX / RX System error (main program hang-up)
##224 TX / RX An error has occurred in the procedure signal in G3 transmission.
##226 TX / RX The stack pointer has shifted from the RAM area.
##229 RX The recording area has been locked for 1 minute.
##232 TX The encoder control unit has malfunctioned.
##237 RX The decoder control unit has malfunctioned.
##238 RX The print control unit has malfunctioned.
##261 TX / RX A system error has occurred between the modem and the system control board.
1-7
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
on.
- Logic board
RX/TX Light Wavers
no it should remain constant.
Mar 30, 2009 | Radio Communications
Galaxy Radios DX- 88HL Base CB Radio Logo
Top Galaxy Radios Radio Communications Experts
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
