http://www.iconservice.com/CustomerService/manualsProductManuals.do?model=PFTL96008&modelName=PROFORM+680+ Please go to that web page and download your user manual free. and then read carefully the page 18-19 in how to adjust the volume.
Hi, First you need to make a test to adjust your headphones wireless system.. .pls follow the step below:
"Connect the headphone base" TO " headphones
output of TV" with 3.5mm stereo headphone jack cable (than Tv should
mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats it..now lets go to second step..
Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to
switch / use "RCA Audio output plugs-white/Red cable " on the back of
TV instead of TV's headphone output ,since it mutes the whole sound..RCA
output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know. Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
try adjusting the volume on your computer, the computer controls the headphone volume when they are plugged in. the speakers will also mute when the headphones are plugged in. make sure the phones are plugged in all the way, sometimes they stop short.
yellow and red-green are most likely grounds. red is normally the right channel and green is normally the left channel. quick question though, why on earth would you cut the plug off of a pair of 75-90$ headphones?
This information was found on the Dynex website: (http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspx) in the frequently asked question section on page 7. If the solution below dos not work for you. You can either go to the website by copying the web address and putting it in your address bar. Once there you can use the e-mail function to talk to customer support. You can also use the Dynex customer support telephone number 1-800-305-2204 between the hours of 7am and 12 am CST. Give them the model number of your television and the problem you are having with the use of the headphones. I hope this information helps you solve your problem. How do I get headphones to work with my TV?
o
Connect the headphone cable to the headphone jack on the side of your TV.
o
The sound will be heard through both the headphones and on the TV speakers.
o
Press Mute to hear sound only through the headphones.
o
Use the volume buttons on the remote to adjust the volume level.
o
You must remember to press mute again to hear sound through speakers. It will not automatically come on when you unplug the headphones.
if connected to a pc right click on the speaker icon on the right side of the main toolbar in windows then click on playback devices and adjust the volume there.
