Question about Activision Video Game Consoles & Games
Skylanders for wii will not work
The memory chip that plugs into the back of the Wii is not responding
5 Related Answers
132321
  • 9 Answers
SOURCE: wii systems memory
Sorry to tell you this... but once you erase your data.... there is absolutely no way to get it back.
Posted on Jun 12, 2008
Anonymous
SOURCE: Power Outage & Now Wii Won't Power Up...
Just and addendum to sakkyoku's post "Solution #1"--
I had the exact same problem:
-Brief power outage
-All devices plugged into same outlet functioning properly
-No red standby light on the Wii Console
Instead of just unplugging the power source to the Wii, I had to unplug EVERYTHING (SD cards, sensor bar, A/V cable) from the Wii and let it set for several minutes.
When you plug it back in, ONLY plug in the power source and hopefully (as it did in my case) your Wii console will shine a beautiful red light of relief.
Posted on Dec 15, 2008
Anonymous
  • 26 Answers
SOURCE: unable to read disc error
If Wii gives Unable to read Disc Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Posted on Feb 25, 2009
Anonymous
  • 33 Answers
SOURCE: Wii remotes not responding to Wii console
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Feb 26, 2009
Anonymous
  • 32 Answers
SOURCE: The Wii will not read the disc
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Posted on Mar 04, 2009
We have lost a skylanders trap with kaos inside. if we buy a new one kaos will not be inside. any ideas??
No because each Skylander has its own memory to save your data...also traps save there own info...so a new trap will be empty...sorry to say. But that's how they work
Aug 16, 2015 | We Video Game Consoles & Games
How to play eu games on us wii
Most consoles are made with different coding between the US and internationally. Is you have a US Wii you cannot plat European games and vice versa.
May 13, 2014 | Activision Skylanders GIANTS Starter Kit...
Why my wii skylanders giants won't read cd
This will depend on a few things.
1. If sky landers is the only game that will not work then it is likely that it is scratched or damaged in a way that makes it difficult to read. You can buy special cleaner for your cd to help with this if the damage is moderate to minimal. Or use a home remedy like tubing a banana on the side to be read and wiping it all off with a microfiber cloth and giving it a quick rinse (never submerge) and drying. The banana fills in some of the scratches.
2. If you wii has a hard time reading any disc then you should buy a cleaning disc meant to go inside the wii and clean the reader. One designed for computers and CD players should work just fine.
Will not read disc
The disc is probably scratched, if it is I would recommend buying the game again. If not then see if any oher discs are not working if others are messing up as well then it may be an issue with the wii.
Apr 19, 2014 | Activision Skylanders GIANTS Starter Kit...
My skylander on spyro's adventure has a problem, how do I fix it?
Try this :)
If you are getting an error stating A toy on the Portal of Power has a problem, follow these steps to reset your broken toy.
Skylanders SWAP Force
  1. With the toy on the Portal, select Pause.
  2. Select Skylander.
  3. Select Manage.
  4. Select Reset. If you are resetting a swappable toy, you must reset both the Top and the Bottom separately.
Skylanders Giants
  1. Keep the broken Skylanders toy on the Portal of Power and open the Pause Menu.
  2. Return to the Main Menu.
  3. Open Settings.
  4. Select General.
  5. Select Reset Broken Toys.
  6. Select Yes when you are asked to reset the Skylanders toy.
  7. Repeat Steps 5 and 6.
  8. Keep the reset Skylanders toy on the Portal of Power and start a game in Story Mode.
Your Skylanders toy will now work again.
If the screen turns black after returning to the game, try again starting with Step 1.
If the game won't load and you are only seeing an icon on the screen, remove the Skylanders toy from the Portal of Power, put it back on the portal, and try again starting with Step 1.
Jan 26, 2014 | Nintendo Skylanders Spyro’s Adventure...
I have just brought the skylanders giants wii starter pack,when I start the game and it asks for me to put a figure on the portal nothing happens
Are batteries in the portal, is it synced with the console. To sync remove battery cover and SD card cover on the Wii press the two red buttons at the same time they are now wirelessly connected.
Aug 11, 2013 | Skylanders Wii Gaints Starter pack
My wii console can't read my wii U skylander giants disc
I can only pray this is a joke question. Wii ISN'T wii U. That's whyit wont work. It's like putting a wii disc into a ps3.
Dec 01, 2012 | Activision Skylanders Giants Starter Pack...
Portal of power not recognizing Skylander so unable to play game
I had this happen. I tried a wired & wireless portal with the same issue. I reset the game a few times to get it going. I don't think it is a portal issue but rather an issue with the (Wii) game itself.
Apr 08, 2012 | Activision Video Game Consoles & Games
Wii wont turn on
HI,
Mine did the same thing. Open up the small door where you put a memory card and push the red reset button. That may help to clear it. If it doesn't work then the best thing is to have it looked at.
Oct 26, 2009 | Video Game Consoles & Games
Video Game Consoles & Games Logo
656 people viewed this question
Top Activision Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
