It don't drain water, is it plugged up or maybe a bad pump?
It is a common fault that the drain fails to work in
most machines in a period of time and is the most problematic fault in a
washing machine. In all occasions it is important that your observation is most
important and so is vital to the identification /rectification and solution. If
you have noticed that water has leaked then as the drain hose pump/valve and
fittings are located on the underside of the machine it is important that you
look for possible leaks here. In some cases the drain hose would be clogged at
the drain end to outlet of the house and so there will be back flushing
resulting in overflow to the outside. Also the drain pump/valve can be clogged.
Now remove the drain hose clamps and remove the drain pump/valve, clean the
drain pump/valve, use back flushing to clear off all dirt. Now test using power
to see if this works and can be simulated. When refitting, the hose must be tightened
properly. If the pump/valve does not work even with power then it must be
replaced. If there is intermittent power
to the drain valve/pump then the program controller unit is a suspect. Cleaning a pump:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp Finally the washer must be placed with a tilt- use a
spirit level- so that all water will drain to the outlet port and thereby there
is no residual water remaining. Replacing the pump on a Bosch machine, please check
this link for tips:
Hi
This issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
Hi
Dishwasher not draining issue usually occurs due
Daniel
Hi
Daniel
Hi
Daniel
Hi
Daniel
Hi
Daniel
Hi
Daniel
Hi
Daniel
Hi
Daniel
Hi
Daniel
