When a digital camera falls it usually is not a good sign because parts get broken inside the camera, but it does sound like the system board is working because you have menu and display. However! the problem appears to be more lens related, the circuitry that controls aperture and focus is not functioning. It is more cost effective to replace "cheaper" " than repair very costly"
Disc read errors are mainly due to worn out lens or dirty PS2
lens.Clean your PS2 lens to get rid of this problem if your lens is
dirty.Watch this video it will help you to know how to clean your PS2
lens.Watch it carefully.
Remember to keep your PS2 in Dust free environment if you don't want your PS2 lens to get dirty. If your PS2 can not play certain games like Rock band try this tip:
Turn on your PS2 without inserting any disc.
Menu screen will appear like:
Press the (triangle) Button to enter Version Information Menu that looks like
Highlight the Play Station Driver as above and again press (triangle).
New screen will appear like
Highlight the Disc Speed as above and press button,to enter Disc Speed Menu
And set it from Standard to "Fast".
After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
Then again Press and Hold Reset Button till the Blue Light turns on.
Does the menu button work without the cover or the old cover on? If so, is the new cover an official nokia one, as some unofficial ones prevent the buttons working properly due to misfit.
hi u do onething, u remove ur battery and then refix then switch on ur mobile, u press menu button before its go to lock, then if u can u change ur password or u will do factory resetting. before u take back up ur contact and all...
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
It sound like a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem.
In any case it could not make it worse
