HP (ZD929AA) Computer Speakers Logo
Dale Rivett Posted on Mar 14, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Speakers quit working. The computer tests good with ear phones at all jacks. Is there anything I can repair, or just buy a new speaker?
The speakers are six years old. There do not appear to be any screws to allow for doing an inspection and getting it back together Would there be a fuse to replace in this speaker?
Mandeep Singh
Level 3:
  • HP Master 1,184 Answers
  • Posted on Mar 15, 2012
Mandeep  Singh
HP Master
Level 3:
Answers
1184
Questions
11
Helped
474816
Points
3414
Hi Dale,
It would be best to invest any new speakers. Getting these old ones to work will surely turn out to be more expensive. Generally with the old speakers , the cable that connects to the computer gets frayed ,if that is the case you can cut the frayed end a re-solder the jack.
Link of speakers
Thanks for using fixya
Proton
3answers
To whom it may concern, Suddenly I have no sound. Speaker connection seems fine. The speakers came with my Emachine circa 2002 or 2003; I can't remember when I got this thing, and except for the recent...
and first is , he volume turned to zero or muted?
sound from what source, CD or other?
mouse a USB mouse or P/S2 mouse?????????????
never hot swap, any P/S2 device ever. PC off only. allowed.
no100mA not problem for USB unless other things USB are overloading the VBUS 5v bus.
connections not told at all.
first off, exteRnal speaker are powered, or are dead.
3.5mm round plug goes in the green 3.5mm jack on the rear of PC. if usIng a PCI-e sound card it goes there. if goes here the mobo sound must be disabled in bios first.
there is front sound jack same think ,called lineout or phones.
you can buy $1 ear buds in the dollar store to test all this easy as eating cherry pie in fact , it needs no power to run ebuds a key fact.
I can not see your speakers to guess what the are or connectors there and where jacked in to what (3 places green and more wrong.)
if bugs fail that means the PC is failing but only allow one jack to be used, 3.5m green (or marked phones or lineout)
one bugs , one speakers, one phones. never 2 or more at once.
The cause here is bad settings in sound Control panel outputs set wrong.
or the sound card of chip sound has no driver.
device manager shows if sound drivers are wrong.
and first is , he volumn turned to zero or muted?
NO OS told XP home new, still using virus maGNET XP:?
THE READ PORTS SOUND ARE 3X 3.5MM
THE TOP ONE IS SOUND OUT PHONES, LINEOUT
with odd colors there not standards, (wow.
if no sound card in PCI slot(I cant see PC0
the sound is best used at rear left facing rear of PC
and in BIOS That sound chip must be Enable.d
and the coin cell battery not dead as all are this old;.
specs and good docs and good driver from them are impossible
zero.
I see audio drivers 2001, if true wow 21 years old XP only
the PC came with setup CD , lost that?
external speakers
  1. plugged in, rear 3.5mm jack, lineout+phones (not wrong jack)
  2. external speaker needs power and must be turned on
  3. mute off
  4. volume up/
  5. mix sound set for output 3.5mm speakers.
  6. bios for onboard sound not disabled.
  7. OS XP? driver not missing for sound.
  8. xP not infected OMG x10, it is.
2answers
I have a HPvs17 flat screen monitor connected to a hp pavilion a520n. How do I turn on the speakers?
jcdiekfuss, First verify that you have audio signal coming out of the light-green audio-out "jack on the PC!! Use an external pair of "wall-wart" powered speakers to verify. Notify me of result. You can also try to "feed" low-level audio from a radio or CD player "ear-bud" jack to the LCD monitor's audio input jack for testing purposes. Good luck. 12fixlouie
I have turned the tv on and in the top right hand corner there is a symbol for earphones and i cant get the normal sound back on
yoiu likely have a sound output selection in you setup menu .. or in some sets they sense the fact that ear phones are plugged in (switch in the ear phone jack) .. and that automatically shuts off the main speakers .. sometimes the ear phone jack gets damaged and the set thinks there is always an earphone plugged in .. if thats the case then the jack would have to be replaced or repaired ... or you could for the time being, run a cable from the ear phone jack to an external amplified speaker (like a computer speaker .. that would get your sound back at least until repairs can be made ..
Nov 27, 2009 • Cell Phones
2answers
My sound system stopped working
what PC, non stated , only that old monitor
that monitor is 16 years old today, wow , 99% are dead now
long ago, dead when the CCFL lamps burned out long ago
you be lucky it works at all, a fact.
no the USB port is not sound, but they sell USB speakers and head phones that have its own sound system (CHIP_) total that replaces
the sound in your unstated PC, (but is topic 2 not #1)
lets do sound blind, I cant see your pC can I, no photos
or names or models or what cables are attached can I, now.
so sound 101: day: (forget USB for now, ok?)
1: my guess is desktop of some kind, (i use a monitor on a laptop)
2: remove all usb devices now, cept keyboard and mouse.
3: now see rear of PC, see those 3 or more 3.5mm phone jacks.?
sure, see that green round phone jack, that is LINE out.
1.5mm diameter it is, (no set of pins , no USB this)
if you connect ear buds or a real phone jack head phones this works now, (does it , bugs are 1 buck at the dollar store)
eg: click control panel of your unstated windows, click sound
click speakers, mine has many speakers to chose, 7.1, but if old PC it has one speaker click that,. (mine is fancy express sound card,with surround sound, so can yours if you buy the card)
then click tab called,sounds , see asterisk. and test button
this is the best way to test sound first. only this.
This is built in to all windows made. all.
and always works if the sound driver is present.
if the test button fails to work at all. is gray out that is windows way of telling you the sound driver is borked up, missing or corrupted, one of my PC run linux, so.... that be different...
lets say you get this far, ok?
4: lets say a real head phone works on the 1green jack. it must.
forget USB for now, that is advanced stuff that MS does not support but can function good with hard work later.
5: now that monitor or any external speakers sold are all ampified speaker,, no they are NOT just speaker with only a voice coil inside. not at all.
the monitor needs that 3.5mm cable attached,
the amp in the monitor must be accessed, just like real exteral speakers that same do.
on the monitor,here I will read your manual to you now.
so can you why not do that first??????
6:push the menu button on the monitor to get to sound volume/
the FP5012 as a 2watt amp inside that can fail
or someone reset the monitor and the reset puts volume to 0
zero.
the jack is named on mon.
1 x audio - input - mini-phone stereo 3.5 mm - 1
why not just by new external speaker kit (amplified for PC)?
spend like $10?
i found your manual, want it? push center button now.
push menu choice (OSD) 5 , for sound volume
bingo? page 15, in dah manual.
omg, its got its own button on front of mon.
its not in the OSD on this monitor as is most.
http://www.manualsdir.com/manuals/67592/compaq-5017.html
end stock sound systems.
USB is a totally different and more complex topic,
as all USB devices can be, MS even has a warning on the use of these usb sound devices, ask and can send it to you
in short MS says zero support on them ask your vender for that.
do not run onboard sound with USB sound or they will fight each other, until you learn how to control that, ask. we do it all the time here.
ok here is the V button set, below. if this fails
and buds work, the monitor is BAD.
if the buds fail the PC is messed up, (USB not used)
cost of testing $1 (buds)
v-y5lcaykkf42lwqqbpm0ein5s-3-0.jpg buds means ear buds, sold in just about all stores now.
for nada, get some keep them handy of cheap testing.
4helpful
No call volume om samsung e250
This because in your handset there will be 2 speakers
1 is loud speaker and 2 nd one is ear piece speaker....
so the loud speaker is working fine ...
There may be some loose contact in the ear piece speaker or the speaker might have got damaged ...
so if you are good at opening then just open your handset and check if there is any loose contact in the ear piece speaker .. is so fit it correctly ..
or you replace the ear piece speaker with the new one ...
if you are not good at opening then just contact the technician ...
he will do it ...
The ear piece speaker is very cheap so no problem .. just buy the ear piece speaker which is compatible to your handset in the shop if you are doing it by your self ...
the technician might take the service charge for this that s all but the ear piece speaker is too much cheap ..
any doubts reply me
i am always here to assist you
thank you
bye ...
3answers
1helpful
Amplified Speaker System CA-3080 On But No Sound
Do you have a walkman, mp3 player, or any other portable stereo that you can test out the speakers?
This would be the 1st thing I would try. Place the plug that you would have normally going to your computer, and place it in the ear jack of the portable stereo or mp3 player. If you have sound, then I would make sure that your plug is in the correct jack in the back of the computer. Usually, the color of the jack is Green but that isn't written in stone. Just look for the speaker out or "out" where the sound card is located.
Try that and see if you get anything.
Get back and let me know and we can go from there.
Good luck.
mac
Top HP Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
ADMIN Eric
ADMIN Eric
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
