Not getting MIDI signal to LOGIC on mac computer. Using MIDI OUT from Nord Stage keyboard to MIDI IN on MBox 2. Mbox 2 connected to computer via USB. S/PDIF led is flashing on MBox 2. Not seen that before - is this my problem and how do I solve it?
SOURCE: PROBLEM KEEPIN MBOX 2 CONNECTION TO MAC LAPTOP
when i plug in my mbox 2 a message pops up saying audio device is drwaing to much power.. what the hell does that mean
SOURCE: when I plug in my keyboard to my MBox pro 2, I see
i am used compaq c700 laptop and i formet my laptop and i don't have sound drive so what can i do
SOURCE: Mbox 2 and new macbook pro
my Mbox isnt being found by my mac. when i try and install protools it tells me the mbox carnt be found. i have tried different usb cables ect but nothing seems to work.
SOURCE: Can't get my mini mbox usb working for protools 8 after inserting
You were supposed to install the software first (which holds the drivers for the hardware) before you plugged in the MBox. I had the same problem, but I had to use drastic measures and reinstall my OS.
SOURCE: My computer immediately fails when
Try to connect the box to another pc without installing it - if you get the same result then the box is defective. If the box appears to work correctly there then its driver is either corrupted or incompatible. Uninstall it, run a system and registry cleaner, download the latest version and install it.
