I was going down the road and it stopped on me it didnt turn off just wont excellerate. i can start it and when i go to take off it just reves up and wont go anywhere.what can be the problem.
SOURCE: my scooter PanTerra no start, not even turn over
Most scooters have four things that need to be done before they can be started with the electric starter:
Some scooters may have other interlocks on the front brake or the center stand. Check your owner's manual to make sure that you are doing all you need to to complete the electrical circuit which enables it to start.
If the scooter doesn't turn over when you've done all the required operations, there's an electrical problem with the battery. Make sure the battery is charged. If it is, make sure the fuse hasn't blown. If it hasn't, check to see if you are getting voltage to the starter motor terminals. If you are, the starter motor is likely defective.
If the scooter does turn over but still doesn't start you have to check for a spark and make sure gas is getting to the engine. To check for a spark, remove the spark plug from the cylinder, hold the tip of the plug against the cylinder head and crank the engine. You should see a spark across the gap. If you don't, there's a problem with the ignition. Could be a faulty coil or electronic ignition module which will have to be replaced, or it could just be a lose wire.
Hope this helps.
SOURCE: I was driving my 50CC scooter down the road today
Your drive belt snapped. If it is a 50cc, 4 stroke engine, chinese scooter, with a 10 inch rear wheel, then you most likely need a 669-18-30 belt. That is the most popular scooter belt on the planet and is available for about $10-$35, depending on the quality you want. Any scooter shop can change it for you. It only takes about 15 minutes, but expect to pay a chargeable labor rate of .5-1hr since there are unexpected problems occasionally, and there is cleanup time, paperwork time, etc. It should cost about $30-$75 in labor plus parts. Any more than that and you are getting ripped off. You may have other worn parts in your transmission such as roller weights and variator guides. These tend to wear out on chinese bikes around 3000km+. If they are worn, change them while the technician is working on it. It shouldn't cost you any more labor, just the parts, about $12-$20 for the rollers, and $8-$12 for the guides. Cheap belts last about 2000-3000km, good belts last 5000-9000km. Pay the extra few dollars for the better belt, you won't regret it. If your belt broke prior to 2000km, then you may have a defective part in your transmission, such as the rear pulley. That usually comes as a "clutch pack" and generally sells for $40-$90. If you have more than 2000km, it probably snapped just from normal wear and tear. If you can't find a local scooter shop, you can reach us at www.solanocycle.com. We can ship you any parts you need. This repair is not recommended for novices. Although it is easy for those who know how to do it, you can damage your crankshaft and ruin your motor if you do it wrong. Hope this helps.
