Pioneer DEH-P4000UB CD Player Logo
Posted on Mar 13, 2012
Program pioneer remote and stereo cxc8885 - Pioneer DEH-P4000UB CD Player
How to program my sanyogxdb remote to w ok rk my pioneer elite vsx 33 rece v er
To program your Sanyo GXDB remote to work with your Pioneer Elite VSX 33 receiver, you can try the following steps:
  1. Turn on the Pioneer Elite VSX 33 receiver manually using the power button located on the receiver itself.
  2. Hold down the "Code Search" button on your Sanyo GXDB remote until the LED light on the remote stays lit or blinks.
  3. Press the "TV" or "DVD" button on the remote, depending on which device mode you want to program the receiver to.
  4. Enter the corresponding code for Pioneer receivers. You can find a list of Pioneer remote control codes in the instruction manual that came with your Sanyo GXDB remote or by searching online. Enter the code using the number buttons on the remote.
  5. Point the remote at the Pioneer receiver and press the "Power" button. If the receiver turns off, it means the remote has been successfully programmed. If not, repeat the process using a different code from the list until you find the one that works.
  6. Once the remote successfully turns off the receiver, press the "Code Search" button again to save the code. The LED light on the remote should turn off or stop blinking.
  7. Test the remote by pressing other buttons, such as volume up/down or channel up/down, to ensure it is functioning properly with your Pioneer Elite VSX 33 receiver.
If you're still having trouble programming the remote, consult the instruction manual that came with the Sanyo GXDB remote or contact Sanyo customer support for further assistance.
How do I program a new kenwood RC557 remote with my kenwood KDC-MP2035 stereo?
Unless you are a super genius this cannot been done they are only meant to work with the same model, once i have pioneer that needed a remote it took me 5 tries to find the right remote i went to local pawn shop 10$ is what i spent try there, but take the remote to your car and make sure ALL i mean ALL every last one on the remote work properly
Manual for pioneer axd7247 remote?
How do you program the remote to the stereo
I have a pioneer car stereo model #qxa3196 and i wanted to know if it is compatible with an ipod. I was told it would work with the adapter throught the aux setting
QXA3196 is the part number for the remote. According to the Pioneer website, that remote was distributed with the DEH-1200MP, but may be compatible with many other models.
http://parts.pioneerelectronics.com/part.asp?productNum=QXA3196
This unit has an AUX input and will accept audio from any device with a 3.5mm stereo connection, including the iPod.
http://www.pioneerelectronics.com/PUSA/Car/CD-Receivers/DEH-1200MP
What color wire is the remote wire on a pioneer deck, is it always blue
IS there a remote wire in a 2010 Ford Escape stereo? If not can a hook the remote wire from my amp the ignition source?
HOW TO PROGRAM Y IPOD WITH PIONEER STEREO
Don't know what you mean by "program"? Basically you can't program it, however you can play your iPod through your speakers by connecting them with an adaptor that has 3.5mm plug for the earphone socket and RCA cables on the other end, that is the red and white leads. Some stereo units have a 3.5mm socket for sound input also. You can also get a dock unit from Apple with the cables and a remote control. This way you only have to drop your iPod into the dock and then you can control it from across the room. COOL!
Pioneer receiver sx-315
With persistence, I was able to program the Universal Remote Control provided with the cable box to control my new used Pioneer SX-315 receiver. I now can control the tv volume, cable box, auxiliary stereo receiver with speaker system with one remote. Thank goodness I did not have to resort to buying a Pioneer remote control.
I was able to program another previously unused universal remote which I purchased several years ago. However, since the other remote control did not list the Vizio TV. That brand is too new for the remote.
2helpful
Universal home theater remote for Pioneer VSX-305 audio/video stereo receiver
Don't spend a lot of money for a universal remote. Radio Shack has some good buys. I think you are the same person who is having problems with a 305. Get rid of it. You can make a quantum leap at Amazon for less than $200 for a Pioneer.
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
