SOURCE: wii internet connection
This is appearantly a common problem with the Wii. I got this information right off their Support Website.
Error Code: 50231
The Wii console's internet connection settings have not been configured yet. In order for the Wii console to connect online, you must first go through a quick setup process to connect to your home network.
If you need assistance, we can walk you through the process using our step-by-step guide that allows you to follow along. Please click here to begin.
I hope this takes care of your problm.
SOURCE: cant maintain internet conntection simutaneously on my 3 devices
what is happening is ur voice frequency is bleeding in to the ur digital frequency
what u have to do is change channels of frequency on ur router
type 192.168.0.1 or 192.168.1.1 for most routers
in address bar and that should take u in to the interphase of router then go to wireless settings and change the channel that ur running on
rate my service pleas , July
SOURCE: How can I connect my alltel internet card to my wii system
Unfortunately you cannot insert your USB modem into your Wii and have it recognized. Your Wii does not have the ability to operate plug and play devices in the way that your lap top does. The Wii needs to be hooked up to a LAN (local area network) via a wireless G connection from a wireless router or wireless capable modem, or hard wired to a modem or router with an ethernet cable (looks like a big phone wire).
There is a way to share your lap tops internet connection using an ethernet switch (depending on your operating system). If this is an option that you wish to explore and you have the necessary hardware, re-post asking how to set up a shared internet connection using a computer as a residential gateway. Depending on your operating system this can be done quite easily. You will need a computer with an internet connection (which you have), a 10/100 Ethernet switch, and two Ethernet cables. A switch is relatively inexpensive and the wires are as well.
I hope that this helps you with your problem.
Good Luck!
SOURCE: wont connect to internet
you need wi-fi and u need to be close enough to the conection to pick it up.
SOURCE: hotspot shield connects on my mac but doesnot allow access
go to banyone.com and type url in box and its done
