Giving error code E0000001-0002. Turn Manu power switch off & on again. Contact service rep with error code below. What does this mean and how to correct
That's a fuser temperature code that will need to be cleared in service mode. Press the additional functions key * then press 2
somehow my message didnt take all the way. anyways to access service mode press Additional functions key then 2 nd 8 at the SAME time then the additional functions key again. Select Copier from the left of the screen then "Function" on the upper row of menu names Then unde this menu is a clear option go into this and find "ERR" highlisht this and select "OK" in the bottom right of the screen. Power cycle the machine and your code should be cleared, if not cotact your local service rep cause the fuser will need rebuilt.
