Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Hotpoint Aquarius FDW60 won't take in water. Suspected airlock after house move?!?
Posted by Richard on
Ivan Storm
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 32 Answers
Try checking the inlet solinoid , should be 1 for hot & cold, sometimes the solinoid will freeze up due to alkaline buildup .try soaking it in CRL , alkaline deposit desolving liquid .
Posted on Mar 13, 2012
Water not draning
If kitchen side drains are clear then there might be some blockage in the pump system. Check the drain pump is working during drain cycle. If you can hear the pump but the water does not go away then you need to check filters at base of dishwasher. Beyond that you will have to open the pump assembly to look for debris.
see these instructions which might be helpful.
http://jdesbonnet.blogspot.com.au/2010/11/hotpoint-aquarius-fdw60-drain-pump.html
Apr 04, 2014 | Hotpoint 24 in. FDW60 Free-standing...
Please help I have a aquarius FDW60 . The problem
It is likely the flood switch at base of dishwasher has activated due to a leak.
You will have to dry the leak and then try again.
Make sure the mains power is shut when you are working on the dishwasher to avoid electrocution.
Mar 16, 2011 | Hotpoint Dishwashers
Hotpoint Aquarius FDW60 Machine stops halfway through its cycle & the "fast" & "delicate" cycle LED's are flashing - what is my problem?
This sounds like the heater is not energising usually means the heater has failedalthough a blocked or sticking pressure switch will cause the same problem
Apr 14, 2010 | Hotpoint 24 in. FDW60 Free-standing...
My hotpoint Aquarius Dishwasher starts up bu only runs a few moments before stopping with 2 lights flashing " wash " " drying "
I had the problem of flashing lights and water did not pump out.Found a piece of bacon in drain pump wedged between impellor and pump body...cleaned it out...problem solved..
Mar 18, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Aquarius FDW60 tripping electrics
I had the same problem. found out that the RCD was faulty & needed replaced. now o.k.
Sep 14, 2009 | Hotpoint 24 in. FDW60 Free-standing...
I have a hotpoint aquarius sdw60 with the eco 45 light flashing fast and will not reset I have tried turning off the power I have stripped the pump this was clear. then reinstalled it but it is still same
I have a Hotpoint Aquarius SDW 60 The delay 3hr &12hr lights are flashing at the same time. Machine won't start. If the door is slamed shut. It get stuck on the Fast & Prewash 40 degree cycle. and stays there.
Jul 13, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint dishwasher
Switch the machine off and unplug at the mains. Leave for ten minutes, then plug in and switch on. My dishwasher control panel had a mind of its own and did what it wanted including leaving water in the bottom of the machine. The electrics sometimes need re-booting! Hotpoint suggested the solution and it worked for me. Saved me £99 call out charge. Good luck.
Jun 04, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint fdw60 trips consumer unit when switch the plug switch
Hi i have hotpoint FDW60 when i swich the plug and the dishwasher starts then you hear the dishwasher filling up it trips my electric in the house.
Jul 19, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Problem with hotpoint aquarius fdw60 diswasher
My mother has a neighbour who has a new hotpoint dishwasher which caught fire inside (Plastic on door front melted!).
Please contact Hotpoint - if yours is new, check to see if they can replace immediately otherwise its worth booking the engineer to sort £90 - free parts on machines less than 5 years old.
Jan 20, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
518 people viewed this question
Top Hotpoint Dishwashers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
