Question about Planet Audio P9745B / P9740 Car Video Player
Planet audio p9740 user's manual
Posted by basiklee on
  • 2 more comments
  • basiklee Mar 13, 2012
    bought a car with a planet audio p9740 touchsreen and it didn't have any wires. need the wiring pattern for the harness.
  • Mike GeniuS
    Mike GeniuS Jan 19, 2013
    i have no connector! help....
  • Mike GeniuS
    need pinout for a connectorless p9745b! help
  • Mike GeniuS
    i found my connector (pioneer)!
Robert Daniels
    New Friend:
How do I transfer my pic off my digital camera sd card into my p9740 I put the card inside it read it but I can't program the pic to choose one as my screen saver...do u have a solution?
Posted on Dec 10, 2013
Mike GeniuS
  • 24 Answers
Lefttop >>> 1 2345678 <<< right top (looking at back of radio)
left btm >>> a bcdefgh <<< right btm
connector
1 yellow (pwr +) a Black (Ground)
2 red (pwr +) b rca ground
3 green/black (spk-) c rca red
4 green (spk+) d rca white
5 white/black (spk-) e not connected
6 white (spk+) f blue (antenna)
7 purple (spk+) g grey (spk+)
8 purple/black (spk-) h grey/black (spk-)
Posted on Jan 19, 2013
  • Mike GeniuS
    connector
    1 yellow (pwr +)........ a Black (Ground)
    2 red (pwr +)............. b rca ground
    3 green/black (spk-)... c rca red
    4 green (spk+)........... d rca white
    5 white/black (spk-).... e not connected
    6 white (spk+)............ f blue (antenna)
    7 purple (spk+)........... g grey (spk+)
    8 purple/black (spk-).... h grey/black (spk-)
    this is the pinout. it works on my p9745b, though it's a pioneer connector, and d & e may be for dvd cutoff safety wires
How can i get rid of the blue screen that says cant play while driving on my planet audio p9740 monitor DVD
Connect the Parking brake wire to a ground source; either permanent chassis or with a toggle switch.
How to display clock on a planet audio p9745b
bummer - cant find any manuals online about this receiver. Maybe hold down the volume down and see if the option becomes available?
1helpful
2answers
12helpful
9answers
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
1helpful
3answers
1helpful
I Need VX2200D Diagram by Planet Audio
You can find a user manual with the wiring diagram at planet audio's website. Here is a link to a pdf of the manual: http://docs.google.com/viewer?a=v&q=cache:5d-Vrte2v9UJ:www.planetaudiousa.com/support/index.php%3F_m%3Ddownloads%26_a%3Ddownloadfile%26downloaditemid%3D20+VX2200D+manual+planet+audio&hl=en&gl=us&pid=bl&srcid=ADGEESgVApyeRutzYOkF2zFvcSYjjx41jGcX_cCMcEpLsVlrXErVQDZ4CvvrR7zZKYO9gfqRUH4Mk_f_GA4cud4DHa_0ppWSMZxObDvKW6NeIF5f38SmVxRNkvG6vmNXlOgJtzkNJI6G&sig=AHIEtbSePXlAvmQDU-Lflxtlb6xnQFDNyg">http://docs.google.com/viewer?a=v&q=cache:5d-Vrte2v9UJ:www.planetaudiousa.com/support/index.php%3F_m%3Ddownloads%26_a%3Ddownloadfile%26downloaditemid%3D20+VX2200D+manual+planet+audio&hl=en&gl=us&pid=bl&srcid=ADGEESgVApyeRutzYOkF2zFvcSYjjx41jGcX_cCMcEpLsVlrXErVQDZ4CvvrR7zZKYO9gfqRUH4Mk_f_GA4cud4DHa_0ppWSMZxObDvKW6NeIF5f38SmVxRNkvG6vmNXlOgJtzkNJI6G&sig=AHIEtbSePXlAvmQDU-Lflxtlb6xnQFDNyg
I was hooking my Planet Audio P9745B up in my 2000 Honda Accord and it said Warning Video something so it wouldn't show but you could hear the movie and then it showed up on the screen. So i put everything...
Sounds like there could be a shorted wire possibly power but what sounds like happened is the unit grounded out and blew the cigarette lighter fuse. Check fuse box for blown fuse, if this is the case I would suggest pulling radio out and having the wire harness for the radio professionally connected and inspect all connections
Planet Audio P9745B / P9740 Car Video Player Logo
Top Planet Audio Car Audio & Video Experts
ADMIN Canada
ADMIN Canada
ray gallant
Are you a Planet Audio Car Audio and Video Expert? Answer questions, earn points and help others
