Vizio L32 32 in. LCD HDTV Logo
Posted on Mar 13, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Received a lock input message - Vizio L32 32 in. LCD HDTV
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 21, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
562
Points
Trying to unlock but it wont stay on
Anonymous
Level 3:
Top Expert:
  • Vizio Master 14,553 Answers
  • Posted on Mar 14, 2012
Anonymous
Vizio Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2717167
Points
48227
Is the input locked or are you trying to unlock it?
What relay under the rear seat in a 2007 chevy trailblazer run the rear lock and wiper motor?
None < LGM - liftgate control module inside the lift gate does .
Rear Wiper/Washer System Components
The rear wiper/washer system consists of the following components:
• Rear window wiper motor
• Rear washer pump
• Rear wash relay
• Rear wiper/washer switch
• RR WIPER Circuit Breaker 15A / ENDGLASS REG Circuit Breaker 30A
• WASH 20A fuse
• Body control module (BCM)
• Liftgate control module (LGM) / End gate module (EGM)
Your best bet , take it to a qualified repair shop. You have no idea of the complexity of these system's . Communication network between modules etc..... Could have DTC'S diagnostic trouble code's stored in the liftgate control module . An auto parts stores can not read these codes .
Power Door Lock Operation
The power door lock switches are integral components of the DDM and PDM. The switches are two position normally open rocker switches. When placed in either the lock or unlock positions, the switches provide a direct input to the DDM or PDM. The DDM or PDM monitors these inputs and sends a Class 2 message indicating a change in the switch's respective position. Modules which activate the power door lock motors receive the Class 2 message and activate the motor in the appropriate direction to lock or unlock the vehicle's doors and liftgate. The modules which activate the power lock motors are:
• DDM (driver door lock actuator).
• PDM (passenger front door lock actuator).
• BCM (both rear door lock actuators).
• LGM (liftgate door lock actuator).
The DDM, PDM and LGM are directly connected to the respective door lock actuator through the door lock motor lock and unlock circuits. Once a door lock or unlock request has been received, the module will supply battery voltage to one side of the actuator and ground the other causing the doors to lock or unlock.
2answers
I had a locked car light come on in my 2006 chevy malibu, it no longer will drive. doesnt turn off, goes in reverse but when in drive, just revs like the car is in neutral, why?
The lock an car symbol is for the anti-theft system ! By not turning off, do you mean you can't turn the key to the off position or you can turn the key to off but the car won't shut off ?
It sounds like you have a Power Mode Mismatch
The ignition switch is an input to the BCM - body control module an if something happens to the system , the BCM will keep the vehicle in the last known mode Since the operation of the vehicle systems depends on the power mode, there is a fail-safe plan in place should the power mode master (PMM) fail to send a power mode message. The fail-safe plan covers those modules, using exclusively serial data control of power mode, as well as those modules with discrete ignition signal inputs.
You could have an ignition switch problem or something wrong with the BCM .
Discrete Ignition Signals Those modules that have discrete ignition signal inputs, also remain in the state dictated by the last valid PMM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, battery positive voltage, the modules will fail-safe to the RUN power mode. If the discrete ignition input is not active, open or 0 volts, the modules will fail-safe to OFF-AWAKE. In this state, the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle.
This is one you need to take to the dealer because they have a factory scan tool !
2answers
I turned dish on and all I get is snow
Check the input cable to dish box for firmness and the orientation of the dish.
2005 Chevrolet Tahoe Power Windows and Power Locks not working.
The power windows an power locks are controlled by a module , DDM - driver door module . As far as the locks locking when you put the vehicle into reverse an unlocking when you put the vehicle into park , that's how there are suppose to work , automatic lock an unlock feature . When you put the vehicle into any gear from park the locks should lock . Did she hit window lockout function ?
The power door lock system consists of the following components:
• The driver door module (DDM)
• The passenger door module (PDM)
• The body control module (BCM)
• The driver information center (DIC)
• The rear door lock switch
• The door lock relay
• The door unlock relay
• The liftgate lock relay--utility vehicles with liftgate only
• The reversible door lock actuators in each of the doors and liftgate
• LOCKS 20A fuse (rear lock/unlock relay supply voltage)
• ECC 10A fuse (liftgate lock relay supply voltage .
Programmable Automatic Door Locks
The automatic door lock feature can be programmed to control the door lock system. The automatic door lock feature is factory programmed to have all doors lock and unlock. For detailed instructions on programming the automatic door locks, refer to Vehicle Personalization in Personalization.
When the automatic door lock feature is programmed to control the door lock system, the driver door module (DDM), passenger door module (PDM) and body control module (BCM) will lock the vehicle doors if the following inputs are true:
• Ignition 1 input is active.
• All door jamb switch inputs are inactive.
• Cargo door or liftgate/liftglass ajar inputs are inactive.
• Transmission is shifted out of park.
This automatic door lock function will only occur once per ignition cycle unless, a door jamb switch input changes state to active and back to inactive. Then the DDM, PDM and BCM will lock all doors again.
Once the automatic door lock feature has locked the doors, the BCM will then unlock all the doors when the transmission is shifted into park.
Driver, Passenger and Cargo Door Lock System Operation
The front power door lock switches are integral components of the driver door module (DDM) and passenger door module (PDM). The switches are two position normally open rocker switches. When placed in either the lock or unlock positions, the switches provide a direct input to the DDM or PDM. The DDM or PDM monitors these inputs and sends a Class 2 message indicating a change in the switch's respective position. Modules which activate the power door lock motors receive the Class 2 message and activate the motor in the appropriate direction to lock or unlock the vehicle's doors and liftgate. The rear door lock switch provides a lock and unlock signal to the body control module (BCM). The BCM upon receipt of a lock or unlock signal will control the rear door lock relays and also send a Class 2 message to the DDM and PDM to perform the appropriate function.
• The DDM (driver door lock actuator).
• The PDM (passenger front door lock actuator).
• The BCM (both rear door lock actuators and cargo door/liftgate).
The DDM and PDM are directly connected to the respective door lock actuator through the door lock motor lock and unlock circuits. Once a door lock or unlock request has been received, the module will supply battery voltage to one side of the actuator and ground the other causing the doors to lock or unlock.
The rear passenger and cargo doors differ slightly in that they use lock and unlock relays. The relays supply and coil sides receive a constant voltage through the battery voltage supply circuit. The normally closed contacts are connected to ground and the control side is connected to the BCM. Once a door lock or unlock request has been received by the BCM, the BCM will ground the control side of the appropriate relay. This energizes the relay and allows voltage to be applied to either the door lock motor lock or unlock circuits. since the other side of the door lock actuator is connected to the normally closed contacts of the opposing relay to ground, the doors lock or unlock.
I am unable to send SMS with z320i but I can receive SMS
Dear Sir,
Please check your phone message settings.If the message center number is wrong you cannot able to send the SMS.
The center number is different for different Operators.So you may check with your operator to get the message center number.
Once you received the Message center number you can manually input in to your phone by .Go to
Message settings---->message center number--->Input the number and same.
Now you may sent the SMS.
Thank you
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
Eeepc authentication failure
make sure caps-lock hasn't messed your password input
9helpful
2answers
2000 ford windstar power door locks do not work and have checked every fuse
The actuactors for your locks have a little motor in them. In this motor there is a resistor that will give out over time. Usually the locks gradually stop working over time. You can remove the actuator and take it apart and fix by removing the resistor in the motor and putting a peice of copper in its place. Takes about 30 minutes per door if you know what you are doing. Do a google search for ford windstar door lock fix and you will find several blogs with detailed descriptions of the repair.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
