Traxxas Bandit Vxl Brushless Buggy Logo
Anonymous Posted on Mar 13, 2012
Traxxas bandit vxl doesn't work i left my traxxas bandit vxl for 1 day and came back and drove and when i got outside and drove pass my sidewalk to go on the road the esc started flashing red slow
Need help ASAP because im shipping my esc-3s back to traxxas so i need to know whats wrong before i send it because it might be find i think.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 20, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
441
Points
0
Are you running a lipo or nmhi? You could have the lipo cut off turned on and the battery is too low. Or it could have a bad motor. Try hooking up another motor an see what happens. Or try to turn off lipo mode.
5 Related Answers
Anonymous
  • Posted on Jul 08, 2009
SOURCE: traxxas stampede the green light comes on for a second then off
All it was that the brushes were dirty, and they were stuck to the motor. The dealer gently used a screwdriver to move the bushes away from the motor a bit and let them snap back in place. Then it worked. I,m such a new R C guy.
Anonymous
  • 56 Answers
  • Posted on May 30, 2010
SOURCE: traxxas revo 3.3 running problems
Maybe running to lean or to rich. When you accelerate put youre hand where the exhaust is and you should get a light spraying of unburnt fuel over hands(lovely!). If you do you may be able to screw in high end needle in a bit and i mean just a bit. If you hear the engine note raise a bit with a slightly higher pitch then you are running to lean and you will want to unscrew the high end needle valve asap.
Also check youre idle screw and make sure thats not closing the carb and stopping any airflow into engine. Let me know how it goes.
Anonymous
  • 88 Answers
  • Posted on Sep 27, 2010
SOURCE: i need to rebuild the inside of a traxxas xl-1 esc
You can send it back to Traxxas and they will repair it for $15 plus $5 shipping/handling if there is no signs of abuse. A new xl-1 esc is $60 from Traxxas.
Anonymous
  • 88 Answers
SOURCE: Traxxas EVX-2 ESC blinks red,
It sounds like the esc needs programmed. The vehicle manual shows how to, or there is a video at http://www.traxxas.com/products/video/support/070911_programESC.htm.
Anonymous
  • Posted on Feb 18, 2011
SOURCE: vxl-3s velineon problem with speed control
mine did exactly the same thing, I didnt realize something was wrong until I put my heat monitor on it, first was 127 c then jumped to 175, before I could unplug everything it went "pop" . traxxis said send it back for repairs (50bucks ugh) .
I am not going to run Li Po (the 11.1 volt anyway) . I dont think the esc is strong enough, I will let you know what traxxis says.
Rapitly Blinking green light at the VXL-3s on my traxxas Slash 4x4
call traxxas. they can help.might hold down butn. plug bat in then try to program.
WHERE CAN I GET A SCHEMATICS BOOK FOR A TRAXXAS STAMPEDE VXL 4X4 WITH TSM?
Traxxas website has copies of the user manual, parts list & exploded view schematics that you can view, print and/or download. Follow the link below:
https://traxxas.com/products/models/electric/stampede-4x4-vxl-tsm?t=support
My traxxas slash 4x4 vxl keeps making a clicking noise from the transmission
there may be a piece of debris got in there. I had many issues with my traxxas car, and sold it off to someone else. losi makes much better
Vxl 3s turns on when i plug in battery, green light comes on, than red, than blinks through the racing and training modes, wont respond with button push
It sounds like it might just be a case of the button being stuck. The ESC shouldn't turn on just from you plugging in the battery, you're supposed to have to press the button once the battery's connected to power up the ESC.
Programming Your Traxxas Electronic Speed Control
CANNOT GET GREEN LED ON 2218 TRAXXAS RECEIVER
Hi I am having problems with my 4x4 slash 1/10 scale
When I turn on the vxl-3 and that turns green but the traxxas link goes red for 3-4 sec then starts blinking red can anyone help please
2answers
Problem with my traxxas stampede xl5 just stopped working.
It sounds like the battery is defective, that causes it to lose it charge very quickly.
Hi my name is fabio i have got a traxxas nitro petrol . the problem is it wont start it is a pull start one and i have took the glow plug out and heated it up but steal dnt wona go any sugestions ?
So you never had it running yet? Or did you ? Can you turn the motor by turning the flywheel ? If not it is seized and you need to heat up the motor to turn the engine again. Leave it at BDC ( bottom dead center) when you turn it off.
How can you adjust a traxxas rustler for a novice driver so it doesn't go so fast?
When turning on, press and hold the button on the ESC until it flashes 1, 2, 3 times then let go of the button. You are now in novice mode.
5helpful
3answers
Vxl-3s velineon problem with speed control
This problem is very common with the traxxas vxl 3-s speed control. If you were previously running it in 70 degrees or above without a cooling fan, hobbytown is correct. If you have a fan, or it is cool outside, try your best to return the speed control for a new one.
Top Traxxas Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
